Question about Zebra Stripe S300 Thermal Label Printer
Print drive belt
I need a new belt what is the part# and the length so i can get one locally if need be
    Problem Solver:
  • 9 Answers
I've ordered them twice over the last few years and have used part number 45189-5 and 45189-8. A quick look on the web and i've seen a couple of other numbers after the dash. I have one. Never been used. If you can't find one. $10. undercovertc at yahoo dot com
Posted on Aug 31, 2009
I have the right belt so Zanussi tells me, but it seems to be 1 inch short. I have loosened the motor and everything else, but it is too short. The belt has the number 1196 . HELP
You have not specified the model of washing machine and it is impossible to give the correct answer. But I can generally explain the characteristics of the belt. It is elastic drive belt 1196 J5 which means that 1196 mm is the working length based on the belt mounted on the pulleys. "J" and "H" means shape of the drive belt and finally number after word (J5) means number of teeth (could be: 4,5,6,8) .The length marked on the drive belt (1196,1217,1280 etc.) is the working length based on the belt mounted on the pulleys. For a given working length, the belts - which consist of different materials - have a different degree of elasticity. This means that, when not fitted to the appliance, their lengths may be different. It is normal that the length of a plastic belt not fitted to the pulleys is three or four centimeters greater than that of a rubber belt. Also, both types of elastic drive belt are shorter than the working length and therefore it is a little more difficult to replace but not so much that you have to lossen motor.
Please follow this link:
https://www.youtube.com/watch?v=yC21q2-eAfI
Dado
Sep 17, 2015 | Zanussi Washing Machines
Zanussi fls 1284 - how is it possible to make the right belt fit - I have tried and tried - it will not fit. What can I do?
Dado
Sep 13, 2015 | Zanussi Washing Machines
What is the actual drive belt size in inches for 300ex
IT is likely that the proper part number is listed on a tag under the hood. If not you can get the units model and serial number off of a tag under the seat and your local AYP dealer can get you the proper belt.
I suggest getting the proper belt. First, there is not much cost difference. Second the ' v' on the OEM belt is different from an automotive belt and will last longer. Lastly, AYP lengths are usually a bit off like 1/2 x 95 5/8 so the even numbered automotive belts wont be the correct length.
Nov 19, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
AC Belt Needs Tightening on 98 Jag XJ8
If you are not competent to adjust the fan belt, a local garage or mechanic can do that for a small fee. Probably wise to fit a new belt at the same time, being an older model.
Jun 25, 2017 | Jaguar 1998 XJ8 Base
Turntable drive belt slips off?
If you measured the worn belt, it might have stretched by 5-8% from the original length. Thus the new belt could be too large. I can't find a reference to the original Technics SG2500L belt. However one site, http://www.turntablebelts.com/panatech.htm , suggests that the appropriate belt may be the FBM 23.6" (60 cm). This is the generic belt for a range of Technics turntables. If they list a turntable model, then they know a different belt is needed.
The best way to measure the belt length is to wrap a string or wire around the belt path on the turntable. Follow that path exactly. Mark the point where you overlap the string or wire. (In case you keep your fingers on the end of the string, mark both the start and end points by drawing your line across both sections of the overlapping string.) Remove the string or wire and lay it flat. Measure the length from one mark to the other. That's your true belt length.
I hope this helps.
Jan 05, 2018 | Audio Players & Recorders
How do you get the alternator out of a 2003 Focus SE, 16V Zetec DOHC?
Disconnect battery ground cable
Remove the ground wire (black) from the alternator
Disconnect the positive wire (red wire held on by a retaining nut) from the back of the alternator
Now disconnect the wire harness from the alternator
Remove the drive belt
NOTE: Some models use a belt tensioner that applies tension to the drive belt.
The best tool to use for this job is the serpentine belt too.
If you can borrow one from a neighbour you can get one at PartSource. (Part# 648451)
On other models you will have to loosen the adjusting bolt on the alternator bracket.
If you're not sure about how to remove the drive belt, visit your local PartSource for free print outs of car specific instructions.
Take off the mounting bolts from the alternator bracket
Now remove the alternator from the engine compartment
Installing Your New Alternator
Put the alternator in the engine compartment
Install the mounting bolts that connect the alternator to the alternator bracket
Connect the alternator wiring harness
Now connect the positive wire to the alternator
NOTE: Your new alternator should come with a retaining nut.
Remember to remove the nut before you install the positive wire.
If it doesn't keep the old nut.
Connect the ground wire to the alternator
Now install the drive belt
This is a great time to replace your old worn out belt. When inspecting your old belt look for signs of cracking, oil soaked, hard glazed, splitting or fraying.
All these signs mean it's time you replaced your drive belt.
If your vehicle no longer has the belt routing diagram under the hood, visit your local PartSource for a free print out of the belt routing diagram.
Reconnect the ground battery cable .
Feb 19, 2011 | 2003 Ford Focus
Need a supplier for a drive belt for a bridgeport varidrive milling machine I cant seem to find a supplier or a part number anywhere
Take the old belt to a local power transmission dealer in your area. Those types of outlets offer various parts such as the various belts needed for industrial equipment. Even without a number on the old belt they should be able to type and cross it based on dimensions, angles and overal length.
John
Dec 15, 2010 | Jet Equipment & Tools 690182 9 X 49 R8 3...
I need to replace my serpateen belt how do i do that?
This label shows the accessory belt routing on a Lumina with a 3.1L engine
  1. Disconnect the negative battery cable.
  2. Remove the drive belt shield.
  3. Fit a 3/8 inch breaker bar or ratchet to the square hole in the tensioner. Lift, or rotate the tensioner off of the drive belt. When the tension on the belt is removed, slide the drive belt from the pulleys.
To install:
  1. Taking care to follow the proper routing of the belt, slip the belt onto the pulleys. As a help, note that the water pump pulley is usually driven from the back (smooth side) of the belt.
  2. Fit a 3/8 -inch breaker bar or ratchet to the square hole in the tensioner. Lift, or rotate the tensioner and, with the belt in place, gently release the tensioner.
  3. Verify that the belt is correctly routed and aligned in the proper grooves of the accessory drive belt pulleys. Inspect the drive belt length scale on the drive belt tensioner for the proper indicated length. If the drive belt length scale does not indicate the proper installed length, the belt may be incorrect, incorrectly installed, worn out or the tensioner may be defective.
  4. Connect the negative battery cable. Start the vehicle and verify correct operation.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 58; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Dec 09, 2010 | 1997 Chevrolet Lumina
How to install 03 ford focus alternator?
Removing the Alternator
If you're not sure about how to remove the drive belt, visit your local PartSource for free print outs of vehicle specific instructions.
Now remove the alternator from the engine compartment There. You've removed the alternator. How easy was that?
Nov 19, 2009 | 2003 Ford Focus
A/C Compressor & Serpentine Belt
some parts stores offer a bypass pulley and belt kit. check local parts house. good luck . also you can get a junk yard compressor. that dont work but does turn and be riding again.
Sep 10, 2008 | 1999 Plymouth Breeze
Zebra Stripe S300 Thermal Label Printer Logo
62 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
