Printer won't stop printing alignment sheet, following changing of ink cart.
HP provides a paper alignment sheet, that my printer prints, after installing a new ink cartridge. The intructions are to insert the paper alignment sheet back into the printer, and without specifiying (by picture instr. only) , push either the print button (color or bw - does not specifiy) or scanner button (does not specify) , to allow the printer to align itself.
However, the printer will not stop printing the alignment sheet. It re-prints the sheet, every time I turn on my computer and printer. What do you suggest?
  • 1 more comment
  • treeguy11 Dec 20, 2008
    I have the same problem. Any advice?
  • tmumolo Jan 07, 2009
    hp all in one c3100 prints a head alignment page every time it's started. how do i stop it. have tried the scan solution but it didn't work.
  • dunkman Feb 22, 2009
    I have the same problem with my HP1350. Every time I start my computer my printer prints out an alighment sheet. It is a total waste of paper and ink. Anyone know how to stop this?
My printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Posted on Jan 11, 2009
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
How to turn off test print on a HP DJ 6122.
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 06, 2014 | HP Deskjet 5940 Photo InkJet Printer
Stop continual printer printer alignment hp 8500
If the Printer is printing alignment sheet, You need to re-align the printer one more time.
1.Press the Setup Button
2. Scroll to Tools
3. Choose clean Printhead
4. Let go through the process.
5. After the printer has printed alignment sheet, Turn off the printer and turn on.
If the issue still persist, Change the cartridges which are low on ink and the printer will re-align itself.
Regards,
Suhail
Oct 08, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have a HP PSC 1410 printer Every time I turn it on, it prints a "Test Page". The Check cartridge light is On, but I just had the cartridges filled. "E" shows in the Copies section I am only printing...
I suspect by "Test Page" you may mean alignment page. If the printer senses a problem with black or yellow colors it will continue putting out this page each time you start the printer. Be sure you correctly installed the print cartridges then follow the instructions on the paper to scan it and do a proper alignment. If you have done the alignment chances are something is wrong with your ink. I recommend against getting carts refilled. In the future be sure to use a new name brand ink cart to ensure proper printing. Please consult the following page for detailed diagrams:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00473766&tmp_track_link=ot_recdoc/c00447737/en_us/c00473766/loc:1&lc=en&dlc=en&cc=us&lang=en&product=441115
If it is truly printing a Windows logo test page I'm sorry for time waste.
Oct 17, 2010 | Office Equipment & Supplies
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Quality of print
take out the paper and see if something fell in there, Check Closely, Esp. if you have pet's and (or) Kid's, also go into the Printers software, and try "printing a "test sheet", and "Alignment", and you can also try Cleaning the Cart's if you don't use it often, it'll leave hard spots on the end of the cart's, hope this helps
Jun 12, 2009 | HP PhotoSmart 7760 InkJet Printer
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Mar 07, 2009 | HP DeskJet 920c InkJet Printer
Alignment sheets spitting out when turning on the computer
Replace all ink carts with new GENUINE HP carts. Your machine is not seeing ALL colors.
Jan 31, 2009 | HP PSC 1315 All-In-One InkJet Printer
Not printing at all!
Change your cartridge and then try again
Sep 23, 2007 | Canon i9900 InkJet Photo Printer
My printer keeps printing the test page every time it's switched on
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
Dec 23, 2006 | HP PSC 1315 All-In-One InkJet Printer
1,189 people viewed this question
k24674
jasbo
jasbo
