Question about HP Color LaserJet 3500 Printer
3500 N printer Problem
I cannot seem to find a manual for my printer, it is approx 6 mos old and it has started leaving gray streaks down the side of all papers I print. I am
not sure what is going on? Any help is appreciated. Kathy
  • 138 Answers
Sounds like a fuser issue. Here's a link to the service manual for free to help isolate the problem. Start with the troubleshooting section under image defects.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%203500-3550-3700.pdf
Hope that helps you.
Posted on Aug 26, 2008
Prints a light gray streak down the left side of paper
either the drum developer or fuser if you can show me a sample I can tell you which it is
Apr 14, 2014 | Kyocera Office Equipment & Supplies
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
I have a Canon iR1024A that is leaving black streaks down side of paper... I have changed the toner.. cleaned out where the toner goes... and changed the drum... nothing changed.. can you help me
If you have changed the drum then probably your fixing film was torn. Check if the black streaks on paper is erasable (not fixed on the paper). Check also for signs of film (gray on one side and brown on the other very thin plastic-like material) falling out from your fixing assembly (if you open the left side cover with caution sign the hot portion area).
Sep 22, 2010 | Canon ImageRUNNER 1670F Copier
Continuous streak - top to bottom - on printout.
Try looking for lint, paper, or anything that could have hung up inside.
A piece of something could be blocking the imaging unit.
In the old days, there were wires in the laser printers and papers would shed and leave paper hanging on the wires.
Mar 28, 2010 | Konica Minolta magicolor 2400 Laser...
When printing 2 sided sheets our machine puts dark gray streaks on the paper after printing more than 6 pages. The streaks continually get larger until they cover most of the page.
When you are printing 2 sided sheets the reason you are getting streaks, is your first sided not dry yet. I know it is a laser printer, even laser you have waite a bit.
Dec 03, 2009 | Xerox Phaser 7700 Laser Printer
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Black streaks on printout
Your fuser is worn out. Needs to be replaced.
Mar 27, 2008 | HP LaserJet 5p Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
2 IN. GRAY AREA DOWN SIDE PAPER
There are several things that can cause this. A worn toner cartridge and/or transfer roller can cause vertical smears, but it may also be a worn fuser assembly. The teflon coating on the fixing (heat) roller wears off, and leaves vertical streaks of varying widths on the pages. Sometimes you may see "ghost" images on the pages for the same reason. Open the back door of the printer, and hold down the exit guide on the fuser (carefull, it may be very hot). There are two long rollers, the lower one is black, the upper roller is either grey or shiny brown. That's the teflon coating. See if it's peeled or damaged. If so, replace the fuser assembly.
Feb 10, 2007 | HP LaserJet 4 plus Printer
hi seems like your printer's head is considering retirement not much to do here sorry have a good 1
Apr 20, 2006 | HP Color LaserJet 4500 Printer
HP Color LaserJet 3500 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
