Question about Minolta Office Equipment & Supplies
Minolta magicolor 2300W printer colors are incorrect; color toner levels are 50% or more.
    Genius:
  • 2,035 Answers
Switch off the printer ...Clean the printer cartridges and reset the cartridges and print ...
Posted on Aug 20, 2008
    Master:
  • 763 Answers
Are the colors correct? restart the printer uninstall the driver and reinstall it again. try to configure it on the settings of your computer and print several pages until it became the default colors. hope that helps!
CHARCOIS
    Master:
  • 848 Answers
Just change the settings .............
  • Minolta Master
  • 19,396 Answers
Check that you intalled toners in the correct way, eventually remove cartridges, and repeat toner installing procedure.
Check if it is just a color adjustment problem on printer settings.
  • Ginko
    Ginko Aug 20, 2008
    If colors are dim, also check that toners are not nearly finished.
My konica minolta 2300 prints purples instead of red i have replaced all toner cartridges so the toner levels are ok
it could be problem in color registration.Try to do color adjustment, but also check the trnsfer belt and drum
Jun 05, 2010 | Minolta magicolor 2300W Laser Printer
I did a refail on three of my cartridges on Minalto color 2300 printer.Now the machine is printing blank. What is the problem
Often this is caused by cartridges that are over filled. Try tapping the cartridges to settle the powder down below the detection level. That should do the trick
aqlso change/empty the waste toner bag
Please rate my help++++Thanks for using fixya
May 12, 2010 | Minolta magicolor 2300W Laser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Not printing yellow (64% full)
Go to maintenance and purge ur cartridge.Cheeck regularly ur wiper maybe it will cause clog to ur cartridge.
May 20, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Replcing the black toner on the Minolta Magic color 2300w
You can press the 'rotate toner' button which is the blue one next to the toner indicators on the top panel or you can open it up and with two hands on either side of the entire cartridge, turn it manually. You will hear clicking sounds as you turn it. I've done this safely replacing all four toners twice over now.
Mar 25, 2009 | Konica Minolta magicolor 2500W Laser...
Cant replace a toner cartridge
It's done via the printers internal menu system:
On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300w
color light has nothing to do with this, first try once more to reinstall drivers, if still shows wrong printer, then you have to upgrade firmware, because if you installed the correct mc2300w drivers and status monitor tell you wrong printer there can be 2 things. firmware is broken or printer/computer usb port is broken. so if you can use another usb port or another computer try it or LPT cable. and as a laast thing update firmware.
May 17, 2008 | Minolta magicolor 2300W Laser Printer
73 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
