Question about Whirlpool Dishwashers
Dishwasher soap remains in the soap dispenser following the complete cycle. I have had the washer for a year and a half. The first year, no soap remained in the dispenser. Now about 1/8th of the soap remains and the stainless under it still has a soap residue.
  • 706 Answers
Try cleaning the soap dispenser with white vinegar so that it is free of all detergent, then try using about 1/4 less detergent than you have been to see if you still have any remaining in the dispenser. Also, make sure your drain filter is free of all sediment so that the system can pump the water out freely. Lastly, if you are still getting some soap remains, then try using a sanitary setting that uses the hottest water and see if the excess soap is properly dispensed. Your water temp may not be getting hot enough so this test should help identofy the solution. Hope this helps !
Posted on Aug 20, 2008
SOURCE:
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
Jan 31, 2013 | Danby Dishwashers
The soap remains inside the dispenser, thus door opens up, but soap remains inside....just drips down the door.
What you have is a faulty cycle timer. Replace this and your dispenser will dispense the soap when prompted.
Mar 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
All glasses and plates have a cloudy film remaining after wash
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Feb 21, 2011 | Whirlpool Dishwashers
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Why does soap remain in the soap cup are a complete cycle is run?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
g
Jan 15, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Soap dispenser door has cracked completely in half
go to searspartsdirect.com and enter your model number found on the inner tub or inner door side, then search for the part(s) you need. You will need to remove the outer door panel to replace the dispenser assy, make sure you do with the power off.
Jul 02, 2009 | Kenmore 15762 Dishwasher
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore 74362
I had the same issue and you will never beleive the solution.
Steps to follow:
1) run one full cycle with no dishes or soap
2) run one full cycle with a dishwasher cleaner like Jetdry
3) run one full cycle with a gallon of white vinager
4) never put soap in the extra in and only fill the main soap bin half way.
should work fine from here on out, but never fill main bin more then half way when you do dishes. also run the hot water in the sink until the water is very hot before starting the dish washer.
Dec 19, 2008 | Dishwashers
Filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
Hello chystalsbrr
Welcome,
You said you, filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
You can try by turning off the breaker in the electric box that feeds the dishwasher for 5 minutes and see if when you turn it back on and the washer resets itself, and the soap door opens.
Or push cancel and then rinse and after it is done and goes to the dry cycle stop it and it should be open.
In the use of liquid soap in both a dishwasher and or washing machine you must use less soap. Half that of powder soap.
Or the suds will roll out of your dishwasher on to your floor. And this is not a malfunction on the dishwashers part. NO bad seal or anything!
In a clothes washer it will destroy the seal and bearing in less than 5 years!
Let me know how it goes!
Huuum
Please remember to leave a rating
Oct 19, 2008 | Whirlpool Dishwashers
Dishwashers Logo
631 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
