Question about Lands Phones
My phone has been out for some time. Just noise on my phone. the outside plug in works fine, so I assume it is my inside wiring. This morning I unplugged all my phones, and hooked them up one by one. When I unplugged the dsl filter they worked. When I put it back, just noise. My computer works, can I just leave it off?
  • 79 Answers
Replace the DSL filter. it is needed to in order to prevent interference between phones and DSL service operating on the same line. Without the installation of DSL filters, high-frequency signals or echoes from analog devices can result in reduced performance and connection problems with DSL service, and the high-frequency signals from the DSL service can result in line noise and other issues for analog devices.
Posted on Aug 20, 2008
Springfield precise temp instructions
The outside temp for the inside reading quit working this morning when I went to check the temp.The outside sensor was working fine.
What do I do to get the inside one to work again. The other features were working fine.
Jun 17, 2013 | Computers & Internet
My phone says parallel set on how i fix it
I assume you cannot get dial tone on your Vtech handsets or base unit. The phone is telling you that another phone or device has seized the line, therefore it cannot give you dialtone. You could have another phone or device(fax, modem, etc.) off hook or you could have trouble on the line caused by bad wiring, faulty line cord, or bad outlets. To find the trouble, you need to remove all devices from all outlets and try to isolate the bad wiring, line cord or outlet by connecting a standard good phone to one outlet at a time using a known good line cord. If you are unable to isolate the trouble using this method, try going to the outside interface box and testing the line there. Inside the outside interface box there is normally a test jack with a short line cord plugged into it, unplug the test jack and plug your standard phone into the test jack. If you don't get good dialtone then the trouble is with the service provider and you need to report it to your service provider. If you do get good dial tone then the trouble is in the building wiring, outlets or phone devices. Typically there is more than one pair of feed wires from the interface box to the building outlets. Remove all but one pair, then go inside and check all outlets for dialtone(plug standard phone into each outlet one at a time) to find which are connected to the pair of wires that are still connected at the interface box. If you find trouble on this feed wire( can't get dialtone at any of the outlets), remove it at the interface box and connect a different pair of feed wires, go inside and test all outlets again. If a feed wire tests good(you get dialtone on at least one outlet) then do not remove that feed wire at the interface box and just add the next one at the connection terminals in the interface box then retest your outlets again. Work your way through all of the feed wires and outlets in this manner to isolate where the trouble is. A bad wire, line cord, outlet or phone can produce a short or partial short across the telephone wire pair that will appear to your Vtech phone as if a parallel set is in use. It can sometimes take quite an effort to locate a bad wire or outlet. Good luck.
Feb 02, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
Phones completely dead no incoming or outgoing calls lcd display is on and charge lite is on
Assuming you have followed all the setup instructions, try reseating then changing the phone cord or verify the one you have by swapping it with one from another piece of equipment ie; another phone, answering machine, computer modem. Sometimes the small plugs do not make great contact with the very fine wires inside. Also look for any bent wires in the phone plug and the reciever any small missalignment of the pins can pvent the phones from working.
This is very rare but newer digital phones will not work on older rotary dial networks that are still used in some rural areas.
Dec 08, 2010 | Uniden Cordless Phone
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
No phone calls can be received but my computer work on the phone line I get no dail tone on the phone and a busy signal when call from outside phone
check ur phone wire on inside.if they r fully plugged in...then it is an outside wiring issue.i had the same problem,and i had 2 raise cain with my phone company until they acted!they finally shimmied up on the pole and replaced the outside wires & now my phone works really good!
Sep 23, 2009 | Lands Phones
Env2 flip screen (the keyboard screen) blacked out, but...
walk outside with your phone in hand. with one hand, hold the phone firmly. with the other, grab a baseball bat. step out into your yard, or maybe the yard of a neighbor you don't like. throw the phone straight up in the air, then grab the bat handle firmly. swing away at that bad boy. fetch the phone and repeat the process if you are not fully satisfied with how your phone functions after one whack. hope this helps
Nov 25, 2008 | Verizon Communications enV2 Cellular Phone
Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Aug 22, 2008 | Dell Inspiron 6400 Notebook
Ruud Problems
compressor is probably bad. disconnect it tape the wires off and start unit. if breaker doesnt trip it is the compressor.
Aug 17, 2008 | Ruud UAKA030 Air Conditioner
Lands Phones Logo
192 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
