Question about Hotpoint RLM80 Refrigerator
Hotpoint Refridgerator RLA61 leaking at the bottom
My hotpoint fridge RLA61 is leaking at the bottom. The bottom shelf of the fridge is wet and its leaking on to my floor. I have no idea where there the water is coming, its not comin from inside the fridge everywhere else is dry, but every morning there is a puddle on the floor. Please some one help me.
  • c-maclean Aug 21, 2008
    Wheres the drain hole?
Clear the drain hole
Posted on Aug 20, 2008
My old Hotpoint is dropping water onto the bottom shelf and along the back of the fridge.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 08, 2010 | GE Hotpoint Top-Freezer Refrigerator
Leak
Sounds like you have a clogged drain the water freezes melts during defrost. You have to take the freezer floor out. to clean the drain.
Apr 27, 2010 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Food freezing in Hotpoint refridgerator
Hello, Your problem is going to be with your cold control/Thermostat this can be located in the control console inside the refridgerator. This part needs to be replaced, the part number is WR9X10042 Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike
Jul 24, 2009 | Refrigerators
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Further questions about one of your posted solutions
make sure that the thermostat id correctly wired in
May 29, 2017 | Refrigerators
Hotpoint RLA61 fridge that thinks its a freezer
hi try itStep 1: Check the bulb to see if it is burned out. If not, depress the push button on the door switch. Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale (instructions for using the VOM are given on page 19).
Step 3: Clip one probe of the VOM to each terminal of the switch and press the push button. The meter should read zero. If the needle on the scale moves above zero, replace the switch with a new one of the same type.
Step 4: Connect the new switch the same way the old one was connected.
Sep 13, 2008 | Refrigerators
Hotpoint RLM80 Refrigerator Logo
876 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
