Question about Nokia N72 Cellular Phone
Always loudspeaker when i pickup my n72 i came direct to loudspeaker and sometime 4 digit came direct
  • sangteack Aug 23, 2008
    yes, but noting happen
    Brigadier General:
  • 7,752 Answers
Have the phone checked by a repair shop
Posted on Aug 22, 2008
How can I connect it to get the most power out of it?
What load is the amplifier designed to drive? It will only deliver maximum power into the optimum load. The loudspeakers are probably 4 Ohms, but the amplifier may well be able to drive 2 Ohms per channel. This means that you need to fit two more loudspeakers This is probably not possible. Alternatively, if the amplifier can be bridged AND can safely drive 2 Ohms bridged or 1 Ohm per channel, you should connect the two loudspeakers together (+ to + and - to -) and connect them to the amplifier output terminals indicated for bridge (often Left + and Right + but sometimes Left + and Right -). If the amplifier can't drive 2 Ohms bridged, do not connect the loudspeakers together, buy another amplifier and connect one loudspeaker to each, with both amps in bridge mode.
Remember that loudspeaker and amplifier power ratings are always massively inflated in the manufacturers' data, often by a factor of 4 and sometimes by 10 or more. You speakers may not be able to cope with a whole amplifier each, so proceed with caution.
Jun 07, 2015 | Pyle 2 Channel 4000 Watt High Power MOSFET...
How to do flash my nokia n72
There are many reasons to flash the Phone,Once for to remove the Mobile hanging problem,Unwanted files ,reset the Phone to original settings and remove the Network Lock,But if you need to flash it from Network lock means You can better use the Unlock code,Because Flash done using the software,they leads to data lose and Hardware crash,But Unlock code is best to Unlock the phone from Network Lock,Get the code from here
Onlinegsmunlock and Unlock it..You need to specify it locked Country,network then order code and Unlock it using the Instructions below enter the code in the Phone step by step...
Nokia N72 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia N72 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N72 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N72 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N72.
3 - Compose #pw+CODE+1#.
4 - The Nokia N72 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N72 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N72
Jun 15, 2011 | Nokia N72 Cellular Phone
What is my n72 security code
You may try default phone and security code
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
type *#06# on your phone to get it.
Aug 19, 2010 | Nokia N72 Cellular Phone
Problems while receiving or making calls
Try restoring it to factory settings, If still the problem persists try to format the handset using the code (*#7370#) which will reset your handset to factory mode settings when you purchased it.
However be careful while using this code as it wipes out the whole data from the phone memory, so before using this code take backup of all your contacts,documents,msgs etc and also remove the memory card from the device.
These troubleshooting will solve the problems if it is caused due to software malfunction only.
For hardware related issues take it to the Nokia care center.
Jun 25, 2009 | Nokia N72 Cellular Phone
Sound problem
no there is not any good software available in net for ur mob even if u use it and dont not work well u may even loose ur warrenty ..... so first concern it wit nokia else check it out wit any local shop
thank u
Oct 22, 2008 | Nokia N72 Cellular Phone
How powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Oct 16, 2008 | Onkyo TX-SV444 Receiver
N72 phone error
format your cell by using this step type *#7370# then your cell restart then type your password like 12345 five digit numbers i think your problem will be solve or format your memory card when doing this
May 12, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
