Question about Bose 3·2·1 II System
Cd stuck for good in bose 3-2-1 (first edition)
Cd disk stuck: whirling noise -"ejecting" - but no ejection. Then the disk starts playing. keeps turning even while "off". Opened the case and front but see no pinhole in drive nor anything that can be opened or pulled!!
what to do?? tried anything suggested here - restarting etc. - but to no avail.
  • 1 more comment
  • zeitunga Dec 07, 2008
    Same thing. Trying to get into the box (the cd is stuck in the machine not letting the cd box eject. No obvious way to open the Bose unit. Wonder if it is a snap-together philosophy?
  • magicosan Dec 07, 2008
    Almost same problem with me. I managed to open the snap in top cover and remove it. But the drive is a closed system which you cannot open. After opening the drawer could see 3 plastic gearwheels, the smalles of it standing high and not being engaged to the others. After pushing it into place the mechanism was unblocked but the drawer was not in the correct place. I fear I have to send it to Bose for repair.
  • uhh what Feb 06, 2009
    I have the reverse problem. The CD/DVD tray is stuck "open". Magicosan - how did you manage to open the case. I've been unable to figure that part out?
    Thanks,
    Bummed
This is an Update to my above problem:
I've managed at last to pry open - with a huge scredriver - the very sturdy black metal clasp that holds down the cd-dvd driver onto the shaft. Now I could lift it up, see the small frontal hole that manually frees the disk tray. I stuck in a pin and at last it opened!!
But... Allas....
I could see that the "captivated" disk had very deep "skid" mark on its playable side, as if sometihng was carving into it. The same carving happened to a new disk I inserted, although it played and ejected normally - only with strange machnical noises. I think that some of the plastic cogwheels that turn or eject the disk got loose. I stuck them in and now it works fine, but I lost confidence in the machine - fearing it may stuck again or ruin my disks.
Posted on Sep 12, 2008
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
Cd stuck
Did you try resetting it?
Jun 04, 2008 | Bose & Wave& Music System
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
A CD is stuck in my bose system How do I get it out?
From an other web site
PART I
PART II
Oct 09, 2014 | Bose & Wave& Music System
CD STUCK IN CD PLAYER
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Sep 07, 2009 | 2007 Chevrolet Avalanche LTZ
Cd magazine stuck in unit. you can hear the motor
There should be a tiny pinhole on the drawer. Put the end of a paper clip into the hole and push lightly. This will release the cd drawer.
Jan 12, 2009 | Bose Lifestyle 25 System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Cds Stuck in cd changer. stuck at no. 6.
    i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
    Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
    Bose 3·2·1 II System Logo
    716 people viewed this question
    Top Bose Audio Players & Recorders Experts
    jjcicala
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
