Question about Copystar CS-2030 Copier
Copystar CS-3035 I have an original that is larger than 8 1/2 on both sides (length and width). When I reduce, it is still cutting off the 1/2". What am I doing wrong?
Your page is still outside of the imaging area. You will have to position the page length wise down the glass and us 8 1/2 X 11 R cassette (R=Reduction) that is what that cassette is used for if you don't have that size cassette use the bypass feature on the machine.
Hope that helps...
Posted on Aug 21, 2008
Water damage to ceiling
Cut off the loose make flat tape and drywall mud
Mar 06, 2014 | Drywall
A rectan Dear Madam Please look at the math questions below. Please help me solve the questions Question 1 : A rectangular tablecloth is 2.5 m long. Trim is to be sewn around the perimeter of the cloth...
1. Well this one is pretty simple. Since you are not supposed to trim the length trim the width instead.
to make the perimeter 0.4 m shorter cut the cloth by 0.2 m width the picture will make it clear.
2. let the length of rectangle be x cm
and breadth = 20 cm
now original perimeter = 2(x+20) cm
new length = x-30 cm
breadth remains same = 20 cm
new perimeter = 2(x-30+20) cm = 2(x-10) cm
According to question
new perimeter = old perimeter /2
2(x-10) = 2(x+20) /2
2x -20 = x + 20
x = 40 cm
hence length of longer side 40 cm.
If you want to directly comm
Feb 13, 2011 | Vivendi Excel@ Mathematics Study Skills...
Hi i have the copystar cs 3035 we never fixed the fan but now it takes forever to print from the network i was told to clean out all the old scans from the hard drive but have no idea how there is no...
Hello Ken,
If the mem bank of printer is full it will slow down, go into Control panal on PC, hit Printer icon, highlight icon and right mouse click, go to prop click empty drafts and copies, and you will see the junk go in bin.
Jun 07, 2010 | Copystar - CS-3035 Printer
I brought my copystar 3035 home from my office, prints fine, but now trying to connect scanner function to home computer. Help
Go to your browser and type in the IP address (I.E. of the copystar into the address bar at the top and you should get a access screen of the copier from there you may have to log in using a password like admin or password it should be at default like a router or something. From there you should find a path to setting up icons that point to shared folders on you local machine or a server..  good luck
Apr 30, 2009 | Copystar - CS-3035 Printer
Noisy Fan on Copier CS-3035
actually fan really works even at sleep mode to exhaust heat, the problem is one of the three fan located at the left side if your facing the machine, is deffective a broken blade causes it to sound bad try to remove its connector, afer all you have two more working
Nov 01, 2008 | Copystar - CS-3035 Printer
Black page
Main charge unit is shorting out.
Pull the main charge unit out of machine.
Take cleaner (included with toner) and clean.
--Look at front and rear for toner build -up on the charge grid.
This build -up causes a short.
After cleaning, reinstall and run.
Oct 21, 2008 | Copystar - CS-3035 Printer
Copy star 3035
The drum unit may need to have the toner collection blade replaced. not the cleaning blade for the drum but the one below it that catches the toner cleaned off the drum. if this blade is old or damaged it losses its seal to the drum and drops tiny specks of toner onto the page.
Hope this helps...
Aug 20, 2008 | Copystar CS-2030 Copier
IP address for Copystar CS-3035
1.On the drivers CD You must have Quick Config tool.Just click on setup Icon and follow directions.
2.Or just press "printer"Button on the operation panel of machine.Go to Interface-TCP/IP and You will see IP adress.
You can also from printer menu select "print Status Page" and page will be printed.You can find IP adress on the status page.
Nov 26, 2007 | Office Equipment & Supplies
Copystar CS-2030 Copier Logo
62 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
