Machine wont do a thing the start button keeps on flashing
  • 876 Answers
Try a simple reset by carefully unplugging the machine, leaving it off for awhile then plugging it back in.
Posted on Aug 20, 2008
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
The start button keeps blinking, WONT LET ME DO ANYTHING
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not spin clothes dry...full of water and wont work. f-21 keeps flashing.
your drain pump is clogged,So the first thing you need to do is,Push the start button again you well hear the machine come on you well hear the pump its trying to drain after about 30 seconds,It well shut off,so push button again watch the machine when the water goes down a certain level.The clothes well start to spin. Now after they get done spinning,push the cancel button.you should be able to hear the door unlock,remove the clothes.Now put Draino Max gel or Rooto-Routor gel in tub of machine and let it set for about 1-2hrs.Now star cycle on heavy-duty wash hot water,it may take a couple of times but it well clean your machine don't mix any othe soaps or bleach during this time. then rinse machine out again to get rid of gel.see if this work for you,are machine does the same thing,its because of dog or cat hair,or something was in a pocket like tissue,or strings from clothes.thanks
Jul 29, 2010 | Kenmore HE2 Plus Front Load Washer
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
Settings wont change
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
May 16, 2009 | Nespresso D290 Espresso Machine
Flashing on/off start button
check your door switch, if unit doesnt think door is closed it wont operate
Feb 24, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
