Question about Wacom Intuos3 Graphic Tablet
Cover of the drawing surface came off..
I got my intuos 3 6 mths ago n lately i found tat the cover of the drawing surface of the tablet seems 2 come off...can i glue it back using superglue or something? will it affect the tablet in any way? pls help..thk u in advance! yrs, anthony
Don't use anything permanent...it is meant to lift, is has adhesive along the top edge to help keep it in place.  For the bottom, sounds crazy, but i used I sprinkled a little pop on it and let it dry, then i didn't stick to it and lift the bottom anymore.  You you also use one of those athletic sweat bands on your wrist, that works too!
Posted on Nov 27, 2008
    Problem Solver:
  • 5 Answers
The Wacom website has a note about this in their support section. Don't glue it.
Posted on Sep 28, 2008
Where can i get a wacom bamboo tablet?
You can buy them new from places like Amazon or directly from Wacom. Just to confuse you more-- it used to be Bamboo, Intuos, and Cintiq. Now the entry level tablets are the Intuos, the mid-level has become the Intuos Pro, and then the Cintiq.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=wacom+bamboo
https://store.wacom.com/us/intuos-pen-touch/
Feb 25, 2015 | Wacom Bamboo Computers & Internet
Illustrator CS5 does not recognize my graphic pen, wether with the Wacom tablet or my new Monoprice tablet. It draws a yellow sticky note kind of thing, it is annoying and I can't find a solution,
I too have a tablet not made by Wacom. For some reason, Illustrator only opens the tablet-sensitive definitions for Wacom. The solution I found: Go to the Wacom site, install the latest intuos driver. You won't be using it, but it will trick Illustrator into thinking there's a Wacom installed, the definitions will be active for your pen. Mine seems to work fine now.
Jun 28, 2012 | Wacom Computers & Internet
WACOM GD-0608-U and Window 7
I had the same good results. Just clicked on Intros and Windows 7 to download the driver fro my model GD -0608-U tablet
Jan 17, 2010 | Wacom Intuos A4 Graphic Tablet
When I go into certian programs like inkscape or the newer Gimp my wacom pen wont draw,but it will select items. yet if I use an older gimp 2.0 it works fine I have the intuos 3 ptz -431w actually it did...
I didn't solve it myself (a lady named Linda deserves the credit) ... but the solution at the following URL worked for me when I encountered the same problem with inkscape0.47 and intuos 4 wacom tablet pen:
http://inkscape-forum.andreas-s.net/topic/200534
Thanx, Linda!!!
cheers
zookumar
Aug 07, 2009 | Wacom Intuos3 Graphic Tablet
The mouse on my Wacom Intuos tablet is not working.
I know this question was asked a long time ago, but I just had this similar problem and found a solution to it.
1. Install the latest Wacom drivers for your device
2. Open the Wacom Tablet Properties from the Start menu.
3. Click on the Mouse tool
4. Click on the Mapping tab halfway down the screen
5. Change the mode from Mouse to Pen
Dec 26, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Cover of the drawing surface come off
The drawing surfce is not glued down and should never be glued down. It is replaceable...
It is basically held on the tablet by an adhesive strip (Double Sided Tape) along it's top edge. I was a little worried too, when after spending some time in Photoshop, it lifted away as if stuck to my wrist.
This is not a fault and it will just lay back in it's recess, no harm done.
NEVER EVER glue it down, or when it comes time to replace it, you will not be able too. If it is peeling up and not laying flat, buy a replacement.
Aug 20, 2008 | Wacom Intuos3 Graphic Tablet
Pen pressure and scale problems
I also use Intuos 3 tablet, did you already try replacing the tip and reconfiguring the pen to the screen? You can find this in the driver software, it synchronizes the pen and tablet.
If you already tried that, does the problem only occur in Photoshop? Also, check your brush preferences, you can go back to your default settings and see. If talking to Wacom fails, you might have a bad pen or tablet.
Jul 07, 2008 | Wacom Intuos3 4x5
Marks..ugh
My Bluetooth tablet does that occationally. Perhaps there is a wireless signal inturptig the wacom signal. I find cycling the tablet off then on will fix this. A bit annoying but the only solution I have found so far.
Dec 22, 2007 | Wacom (PTZ930AC) Graphic Tablet
Pen dragging and skipping around the point where I press
Sometimes the grip pen get stucked because of dust or dirt, or the tip needs to be replaced. Clean the tip chamber or use a new one.
Oct 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Graphire 3 tablet pen troubles
scrap the graphire and get an intuos....i have the same problem....I think the pens are cheap...you might need a new pen. try borrowing someone with an intuos pen.
Sep 12, 2006 | Wacom (EP130E0W01) Digital Pen
Wacom Intuos3 Graphic Tablet Logo
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
