Question about HP PSC 1610v All-in-One Printer
Printer Error It reads ERROR:0x805doaof next line 2613:fm_keyword
    New Friend:
  • 12 Answers
If you have internet access log on to HP web site enter the model number of your printer and there is a fix down load that will make your printer work again. Good news it's for free. Just do a web search HP and you will find the site. Good luck, Kam
Posted on Aug 20, 2008
Now i have error code 022-2613 what do i do
I found this message on the internet :
If you are getting error 022-2613 when linking your Nintendo Network ID from your Wii U to your 3DS, you should check your entered email
..hope it helps
Oct 25, 2015 | Video Game Consoles & Games
Dont have the cd for HP photosmart 2613 all in one
Goto the HP/Compaq website and download what you need from them. Make sure you use your model number when doing a search.
Apr 09, 2011 | HP PSC 1210 All-In-One InkJet Printer
How can i clean my printer ? difficult to read all the lines.. tops of some of the lettering is gone or cannot read? some of the lines r clear and then the next lines r faded or letting is not dark enough...
The print heads are all gunked up with extra dried ink. Go to start, to the control panel next, to the printer, right click on your mouse and the preferences for the printer should come up and MAYBE it will allow you to clean the print heads. Not all canon's have this ability.
Aug 22, 2010 | Canon Office Equipment & Supplies
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
MY HP Photosmart 2613 All-in-One Printing has gone very slow in
It is not a big problem
u r able to solve it
before printing check pending status of printer
means some times pending print are create a big problem to after prints so first check it
and
one more thing
check u r printer settings
Jul 22, 2009 | HP PSC 2410 All-In-One InkJet Printer
Error:0x805d0a0f 2613:fm_keywords_motor.c what does this mean please
This generally means a fatal error, however. I would go to www.hp.com
click on support and troubleshooting on lower left of this page then in the next window click on contact HP and under that Chat online . the online techician can give you help with the code and a solution if there is one.
Good luck to YOu and thank you for using Fix YA!
Aug 21, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1610v All-in-One Printer Logo
48 people viewed this question
Ben Johnson
