Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore mod.# 50522101
Just bought used- plugged in came on- 24hours later still no cold air.
  • 943 Answers
Hi is the compressor running if it is you bought a dud sorry
Posted on Oct 30, 2008
Maytag 51105349JA refrigerator top freezer snowing up and won't stop running
Defrost thermostat, defrost timer or defrost heating element is bad. Because of that the evaporator is clogged with ice and the cold air cannot get to the fresh food section. Therefore the thermostat control doesn't get cold enough to turn off the compressor. On the other hand the temperature thermostat may be bad and stuck inn the on position causing the ref to operate continuously thereby defeating the defrost cycle. Uplug the ref and allow it to thaw completely. (24hours). Then while its quiet... turn the thermostat to OFF or 0 and then to the coldest setting and listen for a click sound. No click sound means bad thermostat. Later after thawing plug in refrigerator and observe function after 2 hours and check for cold air flow to the fresh food section. If the refrigerator appears to be okay... the problem is a defrost issue. Most typically a defrost thermostat is bad, but when behind the freezer panel is a good time to perform an ohm/ continuity check on the defrost heating element.
Feb 08, 2014 | Maytag Refrigerators
Have right parts but connection is wrong on stator for rsp on kenmore oasis mod, 110.27087603 rsp #10183157 and stator #10419333
W10183157 is the proper one for this machine. If you removed the stator did you maybe get the plug behind the staor when you installed it and can not see it now? Just asking
Feb 06, 2014 | Kenmore Washing Machines
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Kenmore AC, no cold air
If the evaporator tube is iced up entering the coil and cool to warm leaving the evaporator, that would indicate low on refrigerant or a restriction. If it is iced up entering and leaving the evaporator, then, it could be low on refrigerant,blower not running at proper speed, dirty evaporator coil or filter.
You need to check the suction and head pressure and temperature to determine problem for sure.
Jun 07, 2010 | LG LWHD1200FR Wall/Window Air Conditioner
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Fans blowing and moving air -compressor very hot -no cold air
un plug the unit and get a new compressor start relay can be purchased at a appliance parts store
Aug 26, 2009 | Frigidaire FRT17G4B Top Freezer...
Kenmore elite refrigerator
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Jul 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Troubleshoot fridge repair
Your description is a little hard to understand, but sounds like an evaporator fan is not working. Its the one inside the freezer half. Its not visible, but there are vents that air can be felt by if its working. Or remove the panel covering it to see.
Jan 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
286 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
