Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
Tuning to pick up sky feed
I was wondering if you could offer me some advice please. I purchased a Professional 4 way Distribution Amplifier and Sky TV Links a couple of years ago, which I used to distribute Television and Satellite signals throughout my home via the outlet on my Sky box. On my old TV (not digital) I tuned channel 6 into my Sky channel which allowed me to watch and change the sky channels via the remote supplied with the Sky TV Link. I have recently purchased a Dell PC with a Hauppage Win TV-HVR-1200 Hybrid Analog/Digital TV Tuner card installed to replace my old TV, I have connected the TV supply cable to the card and set up the TV signal via windows media centre. It picked up the digital channels OK but unfortunately I cannot find a way to add my sky feed, do you know if this can be done and if so any advice would be greatly appreciated.
  • 24 Answers
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Posted on Aug 20, 2008
    Champion:
  • 208 Answers
Channel 3 or 4 on the sat box output to coax. put tv card in channel 3 or 4 ? ( im in usa not sure if that is applicable)
or you could try wireless rca from sky box to the back of tv card rca yellow input ?
6ya staff
SOURCE:
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
How Tata sky HD superior than Tata sky?
Tata HD has clearer picture as it has high definition technology while Tata sky just has standard definition .
Regards
Mar 12, 2011 | Televison & Video
Have lost the link from sky+ to a second tv which was tuned to sky via channel 5 and majic eye on annolog since re tuning i cannot receive sky on second tv
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Oct 21, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Is there a suitable splitter I can use on the RF out on my sky HD box to feed 3 bedrooms allowing digital freeview and magic eye use?
You better off buying a four way distribution amp instead of using a splitter
Make sure the amp is sky and magic eye friendly
Sep 18, 2009 | Televison & Video
I am unable to pick up sky and set it to a position on analogue tv settings. The Tv is sanyo ce26ld90b.
If first we could ensure some connections are tight before moving into TV settings.
You have told me that you are using sky over an analogue connection. Make sure that these are plugged in at both ends (sky box and TV) and that your sky box is on.
Now using your TV remote, enter the TV settings (there should be a button for this specifically on your remote), and opt for Tuning and manual tuning. The layout for most TV settings are similar.
By manual tuning, you are able to select the number on which you want to view a channel (in the analogue case, Sky as a whole is considered one channel on your television)
Now you should be able to use the left and right keys on your remote to tune up and down a range of frequencies, one of which Sky will be on. Once you have found this frequency, you should store it to the channel you have selected.
To my mind, the only thing that would then cause this to reset is if you turn off your TV from the mains each time you finish using it.
Aug 23, 2009 | Sanyo Televison & Video
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Pace Sky plus box
You have 2 choices, software reset or hardware reset. It's up to you what you try, but please read the advice in full before starting - if you break your box, please don't blame me!
SOFTWARE RESET
The following is copied from http://www.ecademy.com/node.php?id=73309
This is useful if your disk usage percentage doesn't go down even after clearing programmesfilms off.
The following is offered on an ADVICE only basis, take care when making changes:
WARNING following this advice is totally at your discretion and anything which happens to your digibox as a result is your responsibility, not mine. You will lose all recorded programmes from your Sky+ Planner.
Sky tech support can talk you through performing a system restore over the phone. To do this yourself, press 'services' on your Sky plus remote, then select option 4. Next press 0, 1, select - you should now see the engineer's menu. Choose option 8, 'Full System Reset'. The box will now take a few minutes to reset itself
Try pausing or recording again, and if the problem persists disconnect the digibox from the mains power. Press and hold the 'left' and 'right' navigation buttons on the front of the digibox whilst you reconnect the mains power. Continue holding the buttons in for about 20 seconds, and when the ring of light on the front comes on, press the 'select' button on the front of the digibox (between the left and right buttons you were holding). The Sky+ recording logo lights will spin backwards and, according to the Sky engineer, this will "clear the hard drive".
Once this is done, disconnect the digibox from the mains power again and this time press and hold the 'back up' button whilst you reconnect the mains power. Continue holding it for about 15 seconds until 3 lights on the front of the box come on and you get a full-screen message saying "Updating system software. Do not disconnect mains supply or satellite dish."
Leave the digibox doing its thing for about 10 minutes and it should be fixed! Try pausing and recording things again... hopefully you've just saved yourself £65
If you've not been so lucky, you'll have to get Sky to fix it for you. Some people report that if you ask to cancel your subscription Sky sometimes offer a free callout to fix the problem - you're more valuable to them as a paying customer than the cost of an engineer callout
Sky customer service's (seemingly unpublished) freephone number. You need to dial 0800 731 6965, then option 2, option 4 March 9, Sky have closed this Freephone number
HARDWARE RESET
Copied from http://www.digitalspy.co.uk/forums/showthread.php?t=484098
Full System Reset via front panel:
  1. Remove power at mains.
  2. Hold LEFT+RIGHT.
  3. Apply power, wait for ring to light.
  4. Release LEFT+RIGHT, press SELECT.
  5. Ring cycles backwards while disk is quick formatted.
  6. If format sucessful PLAY lights up, if not RECORD lights up.
  7. Box goes into standby - wait 30 seconds are wake it up.
Warning: Full System Reset deletes all your recordings and planner entries.
Aug 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
524 people viewed this question
Top Hauppauge Televison & Video Experts
donshafer
Thomas Stauber
Thomas Stauber
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
