Question about IBM Infoprint 1120 Laser Printer
Info printer 1332
After self test, get message "close open door or insert cartdridge."
  • 26 Answers
When you open the cover it has a small silver lever looking piece near the Left hand side. bend this out a little bit so it presses on the cartridge a bit more.
Posted on Feb 04, 2009
Cartridge install
Press the cartridge-door release button, and then open the cartridge door. Make sure that the door is completely open.Insert cartridge properly inside, close the door...
For more info pl visit you tube link:
https://www.youtube.com/watch?v=vjmKxIqyjWk
Sep 17, 2013 | HP LaserJet P2055d Printer
Ink door open meassage
Open cartridge access door, observe left side door switch located, manually operate it feel weather its working or not, close door & check.. not rectified, insert peace of paper in it. check...
Feb 02, 2012 | HP Photosmart C6180 All-In-One InkJet...
HI, I have an HP Printer and model is HP psc 750. Please guide me how can I remove the cartridge of this printer. Thank you. Fahid Amin.
  1. Open the cartridge access door. Figure 4: Open the cartridge access doorc00127636.gif
  2. Raise the cartridge latches for both cartridges. Figure 5: Raise cartridge latchesc00127637.gif
  3. Remove the protective tape from the end of the cartridges. Figure 6: Remove tapec00127639.gif
  4. Insert the cartridges into the carriage. Figure 7: Insert cartridgec00127642.gif
  5. Close the latches, and then close the cartridge access door. Figure 8: Close latchc00127644.gif The control panel displays a message prompting you to align the cartridges.
  6. Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
Oct 28, 2010 | HP PSC 750 All-In-One InkJet Printer
How do I change ink cartridge
Hi Good day!! Turn on your printer and open up the cover the printer head should go center after that remove the ink cartdridge and then you can replace it after replacing close the cover and wait the printer will now charging the ink. Note be sure to lock your ink cartdridge properly if not your printer will not recognise your new ink.. Hope my solution helps you!! Thanks!!
Oct 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My printer says close door or insert cartridge. What door i can't figure it out
It is referring to the upper cover that you use to pull up when you want to see the cartridges or to clean the cartridges... If that cover is closed and you are still receiving this option, then there might be a possibility that the button is pressed permanently, please check that push button...
Cartridge option points to the problem that there might be a possibility that your cartridge is damaged or it has not been correctly placed in its socket... pick it out from socket and fix it again....
Please let me know if there are still any problems.
Regards,
KK
Oct 31, 2009 | IBM Infoprint 1332 Laser Printer
Cant i run a stand alone self test on my deskjet
o check printing capabilities, print a Self Test Report. In order to print such a test follow the next steps:
  1. Turn the printer on and place media in the tray.Set the width adjusters to fit tightly against the sides of the paper in the tray.
    1. Press Power button while opening and closing the printer access door four times.
    2. Release the Power button.Your printer will print a test report.
Oct 28, 2009 | HP DeskJet 3740 InkJet Printer
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Aug 24, 2009 | Office Equipment & Supplies
Keep getting 091-972 Insert Drum Cartdridge error..
Try this
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Jan 04, 2008 | Dell 3000cn Laser Printer
IBM Infoprint 1120 Laser Printer Logo
55 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
