Question about Whirlpool Calypso GVW9959K Top Load Washer
C1 error code
I was washing a load of clothes and the machine wouldnt spin out so I unplugged it the error code was for drain clogged so I took hoses off and cleaned found some towel looking lint in the pump now error code is C1 and I cant find that code anywhere to let me know whats wrong.
  • mary sc Aug 21, 2008
    I was washing a down sleeping bag. It got tangled in the washer and stopped it. My husband took the agitator off, cleaned up what he could, then rinsed it out. Now a Cl message appears during the middle of the cycle and stops the machine, making it useless. Any help would be appreciated.
CL code stands for overloaded motor. Motor is drawing to many amps and cuts out. I suspect a failing motor or something binding that causes the motor to draw to many amps. Don't know how to fix it.
Posted on Sep 01, 2008
Simpson swf85561 wont drain, spin or wash goes to end cycle
It sounds like your outlet is clogged. Unplug the Washer first. You need to take off the back, there is a plastic piece attached to the hose where the water comes out. It may look like an enclosed bowl. Items that get sucked in, socks, scarves, etc... tend to get caught into this. If it is supposed to be clear, but it isn't, then there is something stuck in there. You must pull it apart and remove the laundered item.
A way to avoid this happening in the future, if this is the cause, is to put small washable items in the center of the load. Do not overload the washer.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Feb 22, 2014 | Simpson Washing Machines
Washing machine not draining, LD error code
Through the lower tube of the tub may be able to remove the item of clothing.
Dec 22, 2013 | Kenmore HE2 Washing Machines
Elite kenmore washing machine wasnt spinning clothes out, a code f o2 was blinking on front panel,took off white plug and clean filter. had problems with lock control,figure that out,but when spinning out...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Apr 14, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine isn't spinning clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Nov 20, 2009 | Kenmore Elite 45986 Front Load Washer
Clean clothes
The E20 code indicates a drain problem. Check the drain hose for kinks and obstructions. Next, remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller for broken/missing blades and make sure the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helps and best wishes.
Aug 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 44082 front washer will not drain or fill
e23 is not a valid code.
Please re-check and post if you still need help.
Jan 09, 2009 | Kenmore Energy Star 44092 Front Load...
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
618 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
