Question about Gateway Computers & Internet
My monitor screen is horizonal insteal of vertical.
I called Gateway and they fixed it. thank you
Posted on Aug 21, 2008
How do I get trivia crack to show vertical on my screen not horizontal.
If you hold your phone upright while taking a video, you've surely seen the horrific end results. When you try to play the video back on any other display, roughly 70 percent of the screen is occupied by black bars.
I normally scold people for this behavior, as it makes for terrible viewing. But, in a more proactive approach, the makers of crappy-vertical-videos-app-auto-levels-your-iphone-vids-horizontally-0150499/">a popular iOS app have brought their wares to Android in hopes of finally finding a cure for Vertical Video Syndrome.
Horizon is a video-recording app with a twist-quite literally. Using your phone's sensors, the app ensures that you're always filming in landscape mode regardless of how you hold your phone. With your camera's viewfinder locked onto the horizon, you can turn your phone every which way and the video will remain level.
Feb 25, 2015 | Apple - iPad Air 2 Wi-Fi 64GB
Purple line screen
If it is sing line type (horizonal or vertical), usually there is LCD planel (Mostly, backlight LEDs are broken.)
Jun 20, 2013 | ViewSonic Computers & Internet
Monitor is only showing vertical/horizontal gray/white screen
Your video card has fried unfortunately. If you are familiar with the internal workings of a PC you can open it up and check the power cells on the video card itself, they will usually show signs of damage such as cracking etc. I would have a qualified professional take a look at it. I would recommend www.tigerdirect.com as a starting place for finding a new one
Apr 14, 2010 | Acer AL1715 17" LCD Monitor
The screen has lines and double vertical images then horizonal black lines form and no image is there - a virus?
there is no virus. the problem is the screen. you need to replace it with new screen or let if fix by a technician. they will replace the vertical and horizontal transistor. or so.
Mar 05, 2010 | Acer AL1715 17" LCD Monitor
Just bought Acer X203H. Hooked it up to windows Xp 2003.I make greeting cards with Print Shop 12 The cards or out of shape. They are to long horizonally and to short vertically when I am trying to design...
This is because your screen is widescreen and it is hard to get the dimensions right because when you look at the monitor, the aspect ratio is unusual. You would have to manually adjust your monitor settings (using the buttons on the side of the monitor) to make it look like a normal screen.
Nov 06, 2009 | Acer X203H bd Monitor
923nw samsung resolution problem
on ooptions screen, click box that says only show settings the monitor can handle. Then try changing the horizonal and vertical settings on monitor to match it up with your settings.
On your windows main screen, right click, then properties, then settings, check all the settings
Jul 09, 2009 | Samsung 923NW 19" LCD Monitor
Screen went horizonal from vertical
To get back the original, try this
Use the following Key combination : Ctrl Alt UpArrow
If this does not work, then see if you can minimize all applications and see the desktop. Then right click anywhere on the desktop and select "Graphic Options" and then "Graphic Properties". A window will open and click on "Rotation" tab and then select "Normal". Now click on "Apply" Your screen will return to normal.
Apr 02, 2009 | HP Vs17 17" LCD Flat Panel Monitor
LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Jul 03, 2008 | Sony VAIO VGN-NR220E/S Notebook PC
Vertical/horizonal
There is no button on the monitor that sets this that I can find.
it is likely you changed the rotate settings for the video somehow.
If you have an ATI video card.
you should see an icon for ATI on the tool bar by the time and date .
right click on it and choose catalyst control center. in there you will find the rotate desktop.
if you don't see the icon then you can find it under start/programs/catalyst control center
Feb 25, 2008 | 3Com EtherLink III Combo Network Adapter
Computers & Internet Logo
15 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
