Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox Work Centre XD 125f/E2 red misfeed indicator/status code
Thank you for sending me to the troubleshooting guide at Xerox.
It led me to find the real cause for this problem.
Solution: check for Accordion-style paper jams.
As it turned out, I'm gonna have to replace a "Fuser Gear"
  • 6,487 Answers
You're very much welcome, dont forget to rate my solution FIXYA from your original port , feel free to contact us back...
Posted on Aug 20, 2008
I received a Schylling Little Red Accordian with no instruction booklet. Can I get this?
This is a simple, real accordion. You could simply get a book or video on how to play the accordion.
Amazon Search Results: "How to play the accordion"
If it's brand new, you may want to contact where you purchased it from to let them know you did not receive the instruction booklet, which should have been included.
You could contact Schylling Customer Service to see if they can send you the booklet.
There may be good instructional information on the Internet as well. For example:
Google Search: "How to play the accordion for beginners"
Jan 11, 2012 | Schylling Little Red Accordion
Tip
Nokia Asha 305 display light problem solution
With article and troubleshooting guide solution for Nokia Asha 305 display light problem solution Problem: No display lights, Dark display. Solution: Change LED, Change connector, Make jumper. phonetolls mobile repairing Nokia Asha 305 play light solution Article on this topic Thanks for checking out this Solution. Phonetolls.blogspot.com contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas. Troubleshooting guide Open display back panel carefully and change lights red marking here in this. Remember one thing to do this job, please be ensure that light controller integrated stage is working well then change or check LED (light emitting diode) on display. There are 4 LED with series you can check faulty LED with check meter. At connection with meter probe LED lights show us. There on light emitting diode(LED) Regulated voltage are equal to battery voltage- 4.2. There are series of LEDs if missing one LED then All series is damaged. Warning! During working on this trick if accidentally your handset may have dead or faulted we are not responsible for that please read our privacy policy., ,
on Jun 24, 2015 | Cell Phones
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox m15i copier guide broken
This sounds like the paper path guide that sends the copy by the drum modual and then to the fuser.
If the walls are stained yellow, they the "vains" plastic guides are broken and will cause paper jams. Also after the paper has been fed out of the fuser modual there are other plastic guides that might appear to be yellow in stains. these tips often break and will cause constant jams.
The door guide has to be replaces and the vertical transport may need replacing as well. You would need to get part numbers for this specific model and someone who knows how to dissasemble this machine.
End result, you may need to call Xerox for assistance.
Good luck.
Oct 16, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox Workcentre XD100 Accordion Jam After A Few Copies
What is most likely happening is the pressure and heat roller bearings and bushings are very gummed up.
When you remove a the fuser when its cold, try turning the heat roller gear, I would assume it is very very tight to spin.
What you can do it take the fuser apart, soak the pressure ( soft roller) roll bearings in some alcohol and then clean the heat roll ( aluminium) roller bushings and the end of the heat roll. Make sure you lubricate with some silicon lube the ends where the pressure roll mounts into the small holes in the nip fingers. That should help.
You can call a business called , ( you can google, The Parts Drop) and talk to Britt there. I am pretty sure he has the bearings for that machine. I don't work there, just have done business with them for years and they are top knotch.
You probably want to replace the gear also. Sometimes it can look really good, but be worn just enough to cause a problem.
Make sure you take a real good look at the condition of the rollers before you spend money replacing small parts, so that you don't wind up replacing 40 or so dollars worth of parts only to find out you do need the entire fuser.
Nov 29, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Phaser 8550, scratch lines through printout
For the lines try the remove stripes and also the remove smears procedure you can run from the panel.
The Led screen is a known problem. Send Xerox an E-mail and they will replace it.
You have to pay for phone support if your not under waranty.
But they will replace the screen.
Oct 10, 2007 | Xerox Phaser 8550DX Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
379 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
