I am repeating that I bought a Belkin USB 7 hub for flash drives and it was working properly and all of sudden it won't work. does this happen often? What can I do since there is a lifetime warranty?
  • Kindle Aug 20, 2008
    What do you mean accept and "they" can fix it? Where do I send it and to whom? kindle
  • 19,396 Answers
First of all, some device like USB modems may not work fine when you use usb hubs.
Secondarily, a usb hub, like any other electronic device can get faulty with no apparent reason.
After this premise I can tell you that USB hubs, and USB devices in general can stop working for setting problems, system problems, or electrostatic charges troubles.
When this happens you usually solve the problem by disconnecting USB devices, in this case the hub for ten minutes or so.
At the same time you need to disconnect the computer from power for ten minutes, if it is a laptop you will also need to remove laptop battery to drain power from computer.
If your Hub is powered with a power adapter, check that power adapter is well connected.
If it still does not work after this, then it is probably faulty.
Posted on Aug 20, 2008
    Genius:
  • 1,011 Answers
Sir/madam,
It works with Mac OS8.1 and higher as long as the computer already has an existing and operational USB port(s). Check the power supply and the specs are 6 Volts DC, 4A. The center pin positive for the polarity.
There is no driver or software required for any of the USB hubs. The software is built into the operating system as long as the system requirements in question number one above are meet. Otherwise the hub will not work at all.
thanks
good luck
    Master:
  • 763 Answers
In that case, use your lifetime warranty because they have their on tools to fix your device and i suppose that they are very familiar with your problems. use the advantage of it. hope that helps!
CHARCOIS
My dell win7 desktop won't recognize my usb flash drives
Go to device manager and remove all the entries labeled USB ROOT HUB. After you have done that plug in a flash drive and allow windows 7 to install the drivers again. If this does not work you will have to go
May 19, 2014 | HP PC Desktop
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
Belkin USB Hub 10117 Driver
Those old Belkin hubs did have these issues because of dodgy firmware.
To be honest, they were rather slow speed anyway and you can buy better hubs in the dollar store these days.
Mar 02, 2017 | Computers & Internet
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
I bought a Belkin USB 7 hub for flash drives and it has been working fine. All of sudden it will not work. Do they go bad?
I went online and found Belkin and am sending it back for replacement. I needed an address which you did not supply. Thanks but you kept giving me solutions to someone else's problem. Kindle
Aug 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
