Question about HP DeskJet F380 All-In-One Printer
Scanning on hp F380
Scanning a photo doesnt work , only the power light blinks
  • 4 more comments
  • thedonoghoes Sep 07, 2008
    scanning does'nt work, only power light blinks
  • jay_2004egja Sep 27, 2008
    I don"t know how to scan , but my printer is still working so how do I scan papers for a project.
  • Anonymous Jan 31, 2009
    photo scanning is not working only light blinks
  • annepiet Apr 09, 2009
    The scanner of HP F380 does not work. Instead of scanned, the document is printed. Of course I press the right button, but wihout result. Please help.
    Anne
  • Anonymous Apr 26, 2009
    press the scan button and only the power light blinks for a few moments then stops
  • Anonymous Apr 30, 2009
    i tried megagab99's solution but i got to the HP part and i dont have the solution centre there...now what??
SCANNER DOESN'T WORK, POWER LIGHT BLINKS
Posted on Nov 01, 2008
  • 3 Answers
Ok, go to Start -> All Programs -> HP -> HP Solution Centre
Then click Scan a document or smth...
It will work now!
Posted on Feb 06, 2009
I am having the same issue, but when I click on HP solution center It says no HP devices have been detected, but the printer and copier work...
Posted on May 26, 2010
I have the same problem
Posted on Sep 08, 2008
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    Unable to use scanner
    you may need to reinstall your drivers for your scanner
    Aug 10, 2009 | HP DeskJet F380 All-In-One Printer
    Hp f380 all in one when scanning the image not clear its zooming
    i think your resolution setings is changeing.
    it is in software setings of resolution chagne t to 300*300 .
    Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
    Scanning Problem
    Dear, just walk to the cyber cafe and download the driver for your HP Deskjet F380. The url address is http://www.nodevice.com/driver/Deskjet_F380_All-in-One/get39298.html.
    Regards,
    Rakesh Kumar
    Network Support Engineer
    Nov 11, 2008 | HP DeskJet F380 All-In-One Printer
    Scanning a photo
    Make sure you have the HP imaging software installed and running first if you dont you can download the Vista version HERE that should do it
    Jun 30, 2008 | HP DeskJet F380 All-In-One Printer
    F380 hp all in one
    This issue occurs if the scanning files are not installed properly. Once search for the hpqscnvw.exe file and try to scan from there and check for the result. If you are able to scan then download scan diagnostic utility from the hp.com and run it. If the issue persists reinstall the software.
    May 20, 2008 | HP DeskJet F380 All-In-One Printer
    HP F380 not scanning
    This has happened to me on several occasions with a couple of different HP all-in-one scanner/printer's. The HP driver/program itself may be in a phase where it's attempting to complete a scan, which would prevent you from scanning anything else. You can confirm whether or not this is the problem by restarting your computer and attempting another scan. You'll get an error message saying the scanner is currently in use. You may want to try to completely remove the installation files for the scanner, and reinstall either from the disk or let windows install it for you via "plug and play". Then update the drivers from hp's website. See if that resolves your problem.
    Oct 05, 2007 | HP DeskJet F380 All-In-One Printer
    HP DeskJet F380 All-In-One Printer Logo
    1,364 people viewed this question
    Seeker5211
    Seeker5211
