My Toshiba 62HM15A DLP television won't power up. I just relaced the bulb unit. Now the front panel has a solid green light and a blinking red light.
I just had the same problem last week I had reinstalled another lamp unit on my 62hm14 DLP, and it was doing the same thing both lights were blinking but the tv would not power up and come on.
It was simple once we figured out what was wrong the lamp unit door apparently has a safely mode switch and if the screw is not screwed into the tv to keep it from being opened it will not come on. It was just a safety feature.
We dropped our screw and god knows where it went but we found another, put it in and ta da tv came straight on.
Posted on Dec 02, 2008
HI my tv wont come on the red one stay on and the green the is blinking.
Posted on Nov 21, 2008
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
What are the blinking light codes on a toshiba dlp meAn?
90% of the time your lamp needs replacing.( DLP sets only )
Jun 18, 2009 | Toshiba Televison & Video
LCT50HV black screen and blinking red/green lights
Replace your Bulb which is located on the side panel. U can do it yourself and save some money.
May 19, 2009 | Syntax Olevia 50" Rear Projection...
46hm84 toshiba problem
You will find that when the old lamp exploded, either it damaged the ballast unit or there are shards of glass stopping the cooling fan.
May 04, 2017 | Toshiba 46H84 46" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba
possible color wheel is faulty,call a service shop for an estimate of cost.
Dec 07, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
954 people viewed this question
Top Televison & Video Experts
Electro Med Services...
