Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I bought a Belkin USB 7 hub for flash drives and it has been working fine. All of sudden it will not work. Do they go bad?
I went online and found Belkin and am sending it back for replacement. I needed an address which you did not supply. Thanks but you kept giving me solutions to someone else's problem. Kindle
Posted on Aug 21, 2008
My dell win7 desktop won't recognize my usb flash drives
Go to device manager and remove all the entries labeled USB ROOT HUB. After you have done that plug in a flash drive and allow windows 7 to install the drivers again. If this does not work you will have to go
May 19, 2014 | HP PC Desktop
I am repeating that I bought a Belkin USB 7 hub for flash drives and it was working properly and all of sudden it won't work. does this happen often? What can I do since there is a lifetime warranty?
in that case, use your lifetime warranty because they have their on tools to fix your device and i suppose that they are very familiar with your problems. use the advantage of it. hope that helps!
CHARCOIS
Aug 20, 2008 | Computers & Internet
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
My OS is Windows Vista Home Premium edition. Will Belkinns 2.0 x 7 port hub F5U237v1 will work with it?
Yes it will definitely work it no matter what operating system your computer is using it will be working fine.
Nov 25, 2010 | Belkin (F5U237) 7-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
This is not as complicated as it may sound. You don't need the manager. Bring up the "run" window (XP - Start - Run / Vista Alt-R). Enter the following address [\\192.168.2.1] press enter. The drive will show up. Right click on it and select Map Network Drive. You can then uninstall the useless program from Belkin.
Jan 20, 2009 | Belkin N1 Vision Router
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
My Laptop does not recognize Belkin 7-Port USB Hub(F5U237v1)
Try connecting it to another port or the one on the dock since some devices can be a bit picky about what port they get plugged into.
Mar 15, 2008 | Belkin (F5U237) 7-Port USB Hub
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
