Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox Work Centre XD 125f /E2 red misfeed indicator/status code
Thank you for responding, however as per your suggestion I had thoroughly cleaned the Xerox machine before attempting to find help somewhere else. Yesterday , another expert "scrodamoon" was able to give me an insight as to what to look for and it led me to the troubleshooting guide for Xerox. I was able to find the cause for this problem.
    Master:
  • 623 Answers
Ok thanks for asking
Posted on Aug 20, 2008
Need Win 7 Driver For Xerox Workcentre XD 125F
you can't find one. What you can try is install an older driver or a standard printer driver. that might give you some functions
Dec 08, 2013 | Xerox WorkCentre XD125F All-In-One Laser...
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
E2 error code on Xerox work centre xd series 120f copier
e2 is a paper jam problem. check that the paper guides in the cassette are positioned aginst the paper properly. Also remove the toner and drum cartridge. Clean all rubber rollers that you can get to with a damp cloth ( water). You are especially trying to clean the upper and lower registration rollers that "pinch" the paper. I hope that this helps.
Nov 05, 2009 | Xerox Office Equipment & Supplies
Xerox WorkCentre XD155DF front panel error code "L 6" What does that mean and what is te repair? It occurs during power on and will not continue to power up after the code is encountered.
Hello there breinhart.
Here's your geek-steer ...
Per manufacturer's support page, your device "Xerox WorkCentre XD155DF" is no longer made or sold by Xerox, therefore I'm presuming it's maybe getting a little long in the tooth.
Unable to locate error code "L 6"/"L6" for this device. However, per the "XD Series" user's guide, errors L1 thru L5 provides suggested solution of what's quoted following. Logic dictates L6 would have been paired up right alongside if not for this being an earlier published parent document to your later ...155DF suffix'd device.
[QUOTE]
Switch OFF the Main Power.
Wait approximately 5 seconds.
Switch ON the Main Power.
If the status code continues, call for service.
[END QUOTE]
... which in tech parlance is an age-old, fundamental-as-they-come procedure known as a "reset/reinitialization". Which actually, right up to present day, is a surprisingly often successful remedy.
== SUGGESTION ==
If I were you, I'd first try a quick reset/reinitialization as guide instructs. If/when that doesn't remedy, start from scratch:
  1. Check for/download latest driver(s) from support website
  2. Uninstall device's software.
  3. Turn off device.
  4. Unplug device.
  5. Wait 10 minutes.
  6. Disconnect all remaining cables/cords (both ends).
  7. Inspect for damage/wear and clean each cables' end fittings.
  8. Reconnect all cables/cords.
  9. Reboot.
  10. Perform a registry cleanup.
  11. Reinstall device using latest version software/driver(s), carefully following manufacturer's installation checklist.
That's just about as anal-retentive and thorough a reset as you can accomplish. Many would think it's too anal, but not me. I've discovered over a long period of time, from long-ago up to this very day ... printer type devices are THE most persnickety of them all. They're the house-cat of the PC/IT world ... vay'we, vay'we scay'we!
If still problem-ed, I'm sorry to say there's nothing much else I can offer as a solution, other than what the manufacturer's guidance is: "call for service".
Good luck to you, and please post back ...
  • to let me (and interested others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig) Puget Sound, WA USA
Oct 04, 2009 | Xerox WorkCentre XD155DF Laser Printer
Cleared paper jam, but printer not responding
Did you shut power when removing the jammed paper. If you did not then you have forced the gears against the rotation and may have hurt the transport system
Jul 27, 2009 | Xerox Phaser 6100/BD Laser Printer
Phaser 8400 w/ Maintenance Kit problem
Sorry for the delay in responding. I am sure you have a bad registration clutch. Let me know and I will forward you part numbers , phone numbers and directions. Easy to replace.
Jan 07, 2009 | Xerox Phaser 8400 Laser Printer
Xerox WorkCentre Pro 215 E2 Error Code
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Xerox Work Centre XD 125f/E2 red misfeed indicator/status code
You're very much welcome, dont forget to rate my solution FIXYA from your original port , feel free to contact us back...
Aug 20, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
this is the link
https://www.partsdrop.com/store/
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
Aug 19, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Work centre xd 100, error code c1
C1 indicates the paper is not feeding out of the main tray, your rollers are most likely slick or very dirty.
You can try cleaning them with a soapy cleaner such as fantastic or 409, but I would recommend replacing them.
Not hard to do, you can order them by googling a business called The Parts Drop, either e-mail them or call and ask for Britt.
No I don't work there, they are just someone I found to be excellent and reasonable to deal with parts wise.
Jul 08, 2008 | Xerox Office Equipment & Supplies
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
290 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
