Question about Microwave Ovens
Kenmore micro I have a kenmore model 665.68610891 and all the bells and whistles work except the heat. The display shows the time with a lower case "d" after it. Does the refer to the door??? If so can I repair that myself. I am an IT tech. Thanks e-mail: jeannette.h.smith@usps.gov
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    Let us know if the hard reset does not fix it.
  • William Miller
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
  • Microwave Ovens Master
  • 9,098 Answers
Posted on Sep 01, 2008
  • William Miller
    William Miller Sep 13, 2008
    We call that a FixYa!
The hard reset worked....thanks a million
Posted on Aug 25, 2008
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
Jul 07, 2014 | Kenmore Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
Tip
Or the microwave could be in "Demo Mode" - Check your owners manual. In...
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, your model number did not return any result, contact the seller here to purchase parts. (here in UK).
on Jun 16, 2009 | General Electric Microwave Oven
Won't heat up
Code "d" means the microwave is in "Demo Mode".
Push and hold the "Kitchen Timer" pad for 5 seconds until you hear two beeps.
If you check carefully, You may also find this info in your user Manual under "Demo/Learning" feature
ptishkevich
Mar 02, 2009 | Kenmore 60654 Microwave Oven
Everything works... except the heat!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Microwave Ovens
Maybe one of the fuses, get an engineer to look at it, for safety reasons.
Mar 03, 2008 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore Microwave Problem
"d" may mean demo mode.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
Oct 13, 2007 | Microwave Ovens
Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Nov 22, 2006 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
