Question about Sharp Audio Players & Recorders
The CD player will not read cd's it says there are NO Disc's sharp CD-DP2400
  • 50 Answers
Are u sure the CD's u entered are supported?
If yes, the reading laser is probably broken. Get it looked at.
Posted on Aug 20, 2008
How can I get my CD player to read the discs that are in it.. It says no disc..
HelloIf the CD player do not read any discs, the laser pickup unit is faulty. There is no repair with this unit, only replacement can be done. The cost of this unit will cost around $5 to $8. OK.
Dec 21, 2011 | Sharp Audio Players & Recorders
MY SHARP CD PLAYER WON'T READ CD'S AND SAYS NO DISC.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say no disc.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Feb 22, 2011 | Sharp Audio Players & Recorders
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
Sharp cd-dp2400 suitable remote contols
i have a sharp cd player and the speakers hook up to the cd player and they light up but when i plug in the speakers to play they wont play what should i do
Sep 03, 2008 | Audio Players & Recorders
Cd stuck err 0306 message
Since the cds are stuck inside, you need to open the unit and remove them. There are four screws on the top cover. Remove them (2 on each side) and lift the cover. You should see the cds, remove them, then plug on the unit.
Jun 09, 2008 | Sharp Multi-System Mini Component System...
ER message for CD, Sharp GX-CH150
The optics assembly is having a problem. Either it can not read the disc at all or the disc is not spinning. In any case, the unit will require service. If you can reach the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, update this. Please try to see whether or not the disc spins and report that as well.
Thanks,
Dan
Apr 07, 2008 | Sharp GX-CH150 Shelf System
137 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
