Question about Protron PD-DVR100 DVD Recorder
Set up menu
My kid enter in the set up menu and change the configuration to "pal" and now i cant see the screen to enter again and cahnge it to "ntsc".
please help me
    Genius:
  • Protron Master
  • 1,550 Answers
My friend check in the remote control if they got the progresive scan button or tv sistem and try to deactivate.
Posted on Aug 20, 2008
It's showing the video in a split, black and white screen
could be a pal/ntsc region code problem, either the menu setting is pal and your playing a ntsc region coded dvd or the menu is correctly set at ntsc and the dvd is pal that you are trying to play
Dave
Dec 27, 2010 | Initial IDM-1210 Portable DVD Player
PAL, NTSC
Pls tell us which tv set u have..
Dec 08, 2007 | Mintek DVA-8700 System
I want to play an NTSC tape on a PAL television
This is a VCR alone machine?Not a DVD and VCR combo?VCR alone machine dosen't have auto NTSC/PAL setting to play all the world regions.
May 28, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Using pal/ntsc system dvd player in USA - how to setup to work on ntsc tv
You sould have a button on the remote controls thats says Pal/NTSC, press that button to switch.
Nov 07, 2008 | Durabrand Televison & Video
Sony HandyCam SR10(NTSC) working with my Philips 21PT2443 model
Hi Pawan, Now I am in the same situation as you were. I am planning to buy one sony camcorder from US. But it supports only NTSC. But My TV is philips 29PT7322, User Manual says it supports, NTSC and PAL colour systems. But I am not sure it works or not. Can you please help me with your experience. Thanks in advance, Kinod
May 05, 2008 | Televison & Video
Bose Life styles NTSC to PAL
First, using the remote Turn the unit off.
Then, using the remote Turn the unit on.
Next, Press the [System] button
Next, Press the [Right] Arrow (once)
Next, Press the [Down] Arrow (4 times)
Next, Press the [Up] Arrow (once)
Next, Press [Enter]
Last, Press the [System] button
Done
Apr 12, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Incorrect region code DVD player
if you use a PAL broadcast system where you live ..Use the menu on dvd to set it to PAL system..If you use NTSC change it to NTSC .
Dec 05, 2007 | Televison & Video
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Pal capture format
Out of page 26 in the manual: "When you select "preferences" from the list the following window appears on the screen. it offers some general settings for working with ProPix EVE. the check boxes under video standard enable you to specify whether the project is edited in PAL or NTSC." also from the manual page 30 - go to the drop down menu video device, clicking the button on the right gets you into the video input settings dialog box where you can configure the capture device. under the "video standard" pull down menu you can choose PAL. hope this helps, and check back soon because the manual should soon be online on this site. Good luck!
Jan 25, 2006 | Zio Corporation CameraMate RealTime...
Protron PD-DVR100 DVD Recorder Logo
42 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
