Question about Phonic - XP 5000 - 5000 Watt Power Amplifier Amplifier
Manual Owners Manual for Phonic MM 1002 mixer/sound board
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
Phonic MM 1002
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 20, 2008
How connect external effect consol on phonic mr3243 mixer
Here is the link to the manual however it is not in english but you should be able to figure it out from the drawings.
http://www.soundhouse.co.jp/download/phonic/mr3243.pdf
Jan 12, 2014 | Phonic Audio Players & Recorders
Phonic mm1002
You need a 3.5mm stereo jack to twin 1/4" jack plugs. That will get audio from your laptop to the mixer. Then, being Peavey, probably a pair or jack to jack 1/4" screened leads for signal from mixer to amp. Then loudspeaker leads to suit your amp and speakers.
Jan 02, 2014 | Computers & Internet
Operations manual
Here is a link to your manual, hope it helps.
http://www.phonic.com/en/helix-board-18-firewire-mkii.html
Nov 27, 2013 | Phonic Helix18fw 18 Channel Mixer with...
Phonic mr3243 manual
Try this link however it is in Chinese. You may have to contact the OEM for the manual. http://www.soundhouse.co.jp/download/phonic/mr3243.pdf
Sep 03, 2013 | Phonic Audio Players & Recorders
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
What is the power input voltage required to operate the phonic 1805x audio mixer? is this an AC, or DC input? unit missing power supply and needs to be bench tested for possible future use. no manual...
i have seen the manual. most mixers use ac mains supply with smps inside with +48V for phantom and ur mixer is one of those. u will see a three pin mains connector at the back. but phonic made these mixers for different countries. for us/canada 110~120Vac/60Hz - for uk/australia  230~240Vac/50Hz, europe/ asia 220~230Vac/50Hz.
Look for these or a voltage selector near the power input terminal. if u do not find any of these one sure way of finding which mains supply u should use is to open the case and look at the biggest rectifier filter capacitor on the smps board. 110~120V supply will have capacitors working voltage around 250Vdc and for the others around 400Vdc working voltage. (eg 1000uF, 250V or 1000uF, 400V)
so depending on the DC working voltage of the filter capacitor and country u either step up or step down the mains supply.
18Vac supply will never work.!
the rated mains voltage sometimes are printed on the smps board itself. Hope this helps.
Mar 13, 2010 | Electronics - Others
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Phonic - XP 5000 - 5000 Watt Power Amplifier Amplifier Logo
3,714 people viewed this question
Top Phonic Audio Players & Recorders Experts
Greg Cann
Greg Cann
tom8341
Level 1 Expert
Are you a Phonic Audio Player and Recorder Expert? Answer questions, earn points and help others
