Question about HP Compaq d530 SFF PC Desktop
Will not boot up
I have a hp compaq d350 sff we used it for a couple weeks and now when we try to turn it on all it does is beep three times over and over. The 2 lights that are under the power button are both red, one of them turns green when you hold the button down but as soon as i take my finger of it it turns red again i,m not sure what to do HELP!!
  • 34 Answers
The beeps are error codes there should be a system what it sounds like is 3 beeps then a pause and it starts again. go to www.support.hp.com and click on drivers and downloads then type in your model number and download the manuals there will be a chart stating what the beep code means if you have a warranty go to the liive chat and just have there technicians tell you what it means to save time then repair the error
Posted on Aug 20, 2008
When i pushed the power button it make a beep sound and a flashing red light and pc will not boot.
Please try to clean & re-seat or change your memory RAM and try to turn ON again.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | HP Compaq d530 SFF PC Desktop
I try turning on my hp compaq d530 sff this morning it did not boot and the switch light was blinking red every two or three seconds.
PLS REMOVE THE POWER CORD AND THE BATTERY FROM YOUR LAPTOP AND WAIT FOR 5 MINS THEN RE-INSERT THEM AND ON IT . SHOULD WORK
. PLS REPLY OR COMMENT. THANKS
Jun 15, 2011 | HP Compaq d530 SFF PC Desktop
I have hp d530 sff decktpo pc I can't able to go bios setting window while booting by pressing del or F10 key also pl suggest me.
Sometimes the button to get into the Settings/Bios is F1 or F2.. just go through and test each one of these out. Also sometimes just one press isn't enough, tap on the key a couple of times ot make sure the computer recognizes it.
Mar 30, 2011 | HP Compaq d530 SFF PC Desktop
I have a Compaq Evo and everytime I turn it on it switches between *turning off within three seconds* or giving me 3 beeps and then just staying on without any visual signal. I cant even get into the...
Three beeps at POST (startup) may be caused by an issue with your video card. Check to make sure the video card is seated correctly. If you have another video card, you can try it to determine if the current video card is faulty.
Mar 02, 2011 | Compaq EVO D5S SFF Refurbished Desktop...
My pc hp compaq d530 sff, booting faill.. how can i fix that? thanks.
booting failure usually means the harddrive has become corrupt to where it wont boot or the harddrive failed try to reload windows xp on your harddive
Dec 14, 2010 | HP Compaq d530 SFF PC Desktop
Beeping and flashing light and battery icon, can not turn computer off with on off switch. What is causing this? Checked all plugins.
hi this problem cauld be a number of things you may have to elimonate .......... memory if you have 2 sticks of memory in take 1 out and try 1 at a time .... the beeping if constant is your hard drive whitch is dead..... have you tryed reinstalling windows xp or what ever windows you use may solv the problem......please reply
Nov 10, 2010 | HP Compaq d530 SFF PC Desktop
Hard drive errror
so sorry to tell you but seems that your hard drive is bad now and you may need to replace it however you can try reinstalling the operating system with the help of a disk.
May 20, 2010 | HP Compaq d530 SFF PC Desktop
Hp compaq d350 sff; xp os it won't start up but the two lights on the front blink. what gives?
This is a sign of a "frozen" system. Did you hear any "beep" when the system starts? If you heard a beep, then your video is ok.
Now, you need to open the CPU Casing and remove your RAM modules. Now, connect the PC again even without the RAM. Your CPU must start beeping which indicates that it detected NO RAM.
Now, put in the RAM modules back. It is better if you can swap their positions if your have 2 RAM modules or transfer it to other slot if you only have 1 RAM.
Then start your PC. It should work fine now.
Feb 02, 2010 | Computers & Internet
I have a HP dc7600 SFF. Tried to Install 2 graphics cards no vid
The dc7600 SFF only comes equipped with a 240 watt power supply. I think this may be causing your problems.
I am currently looking for a graphics card for the same comp with the HIS ATI HD 4350 in mind, but the website states that a 300 watt power supply is recommended.
Jan 01, 2010 | HP Compaq Business dc7600 PC Desktop
Hp compaq d350 sff processors compatibility
Your best bet is to work from the existing processor model number, since manufacturers can change the motherboard in a given model of computer from one range of serial numbers to the next. They sometimes also offer the same model of computer with different processors and motherboards at different prices. So you can not tell much from the model number of the computer.
May I also advise you that changing a processor requires a little special procedures, equipment, and knowledge these days. It is not just unplug one and plug in the other any more. If you do not know what you are doing you could easily "fry" the new processor from excessive heat, due to incorrect installation. So look for some help if you are not sure of the details for replacing a processor chip. It's not hard, just that some things that may not be obvious are critical.
Dec 14, 2009 | HP Computers & Internet
HP Compaq d530 SFF PC Desktop Logo
377 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
