Question about Hummingbird GPS
My matrix 27 hummingbird fishfinder with GPS is frozen on a blank screen with two vertical lines going up and down. No matter what I push I get nothing. Also do these lines means its using power from the battery? Came with My Avalon pontoon boat which has circut breakers. THey seem fine.
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
Sunspot on screen humminbird matrix 27 can it fix ?
No, typically with led matrix screens, it is near impossible to find someone to replace screen for cheaper than new unit. Same goes for tvs and computers, etc. Also, and not to be rude but rather if you are faced with buying another unit, do not buy Hummingbird. They are a very cheap quality for not much less money. Best bet will be either Furuno or Garmin. Good luck!
May 14, 2014 | Humminbird Matrix 12 Fishing System
Humminbird
My 787c2 screen just shows lines across it does anyone know were to get a new screen for it hummingbird says they don't stock them anymore try Humminbird Fishfinder Depth Finder Humminbird GPS Chartplotters...
Jun 14, 2013 | Humminbird Boating
Need navionics mmc card for humminbird matrix 67
looking for mmc gold ma card for matrix 67 hummingbird unit one with mas of east coast and bays... and one blank for down loading soft ware. thanks bobbloss@gmail.com
Sep 15, 2011 | Humminbird Navionics HotMaps Classic -...
I need a manual for a Hummingbird 4000D fishfinder
billallen350,
Go to this website for the manual http://www.retrevo.com/support/Humminbird-4000-GPS-manual/id/540dj492/t/2/ .
Thanks for using FixYa and for the great rating.
hardrocko
Jun 10, 2011 | Sport & Outdoor - Others
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Hummingbird GPS Matrix 12
evidently the installer put 2 inline fuses to the power line. After more investigating I located the second fuse which was blown.
Jun 22, 2008 | Audio Players & Recorders
GPS Logo
146 people viewed this question
Top Hummingbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Are you a Hummingbird GPS Expert? Answer questions, earn points and help others
