Question about GE A830 Digital Camera
Dropped Camera I dropped the camera and now it wont turn on by the power button, but it does cut on when plugged to the computer to download pictures to computer. I took it to this guy around my hometown and he said it was the main circut board and it couldnt be fixed. He also said that he couldnt even get it to cut on the way that I do. After picking up my camera I tried my way of cutting it on and guess what! It worked. Please tell me what to do
  • pereedy Sep 21, 2008
    The only way I can get my camera on is by plugging it into my computer first. What about you?
  • 153 Answers
We, the manufacture, would not repair it for you. You can call us at 800 730 6597 for a replacement cost.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Posted on Oct 28, 2008
I plug my FUJIFILM s1600 into computer and hold down play button to view pictures but doesn't work
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Nov 26, 2013 | FUJIFILM FinePix S1600 Digital Camera
Dropped camera, will not take or download pictures
Hi, it sounds like the camera is broken and you need to send it in for repair. If you want to copy your pictures, pull out the memory card and use an USB Card Reader to access your files.
Jul 18, 2010 | Pentax Optio S5i Digital Camera
Casio Exilim EX-Z40 dropped
I dropped my camera when I was turning it on and now the lens wont come out when i press the On Button. Not even view my pictures that i have already there, it just make a beep sound.
Jul 21, 2009 | Casio Exilim EX-Z40 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Pictures will not transfer to the computer.......
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 21, 2009 | Kodak EasyShare C613 Digital Camera
I have a SANYO VPC-T1060 i accidentally dropped it and it turned off with the camera lense out , i tried to turn it on but it wont
Usually when a digital camera has lens issues, they will turn on very briefly, then turn off. Try holding the bottom button in on the lcd side as you push the power button to see if your camera will display stored pictures. My daughter dropped her boyfriends 1060 in muddy water the other day and I cleaned it enough to get it to show pictures but couldn't get the lens to work. A drop or a speck of dirt will stop the lens from working. Haven't had much luck getting lens unstuck, but have replaced the lens unit, usually better to buy new camera unless you are very handy and can find a 1060 with a good lens and bad LCD, which I have done a few times. Looking on Ebay, most of the 1060's being sold 'as is' have bad lens and good LCD's......not good for us....hope this helps.
Apr 19, 2009 | Cameras
Dropped SD400 - buttons no longer work
Not only is a repair shop your only option, you'll probably find it will cost nearly as much to fix than to buy a more recent model.
There are three really weak spots in the SD400 and most small digital cameras: the lens mechanism, the battery door, and the built-in lens shade. Care in closing the battery door so you don't break off the little lugs that hold it shut - using a neck strap so you don't drop the camera - and making sure no sand or grit gets into the lens cap mechanism will make your next camera last a lot longer.
Jun 26, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Dropped the camara,it turns on & everything works EXEPT capture button
Unfortunately, as you have found, the cost to repair these cameras is usually not viable, as it is cheaper to replace the camera.
Even if it is repaired, often the impact from being dropped can cause small fractures in boards or loosen the optics and while they may work ok now, can continually develop faults later.
My advice would be to replace the camera, as you will also get a new warranty as well.
Mar 24, 2008 | Kodak EasyShare V603 Digital Camera
Sanyo s750 camera problem my cameras button to take a pic wont work
Mine dropped two feet on carpet, and it won't turn on. How do you access internal memory?
Mar 07, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sony Cybershot
Turning on may have killed it. however try this. Take the batteries and card out and leave the doors open Take a polythene bag and place in it a quantity of uncooked rice or salt tied into a suitable cloth. put the camera in and seal the bag. leave in a warm dry place for several days This may save it -or it may not.
Aug 02, 2007 | Sony Cybershot S650 Digital Camera
GE A830 Digital Camera Logo
44 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
