Maxtor basics 500gb PN-9NZ2A4-500 will not power up. cannot access data on the drive
  • cubase6 Feb 01, 2009
    When I start my pc without my driver it works, when In connect it my system crashes. I use my hard drive on another laptop and it read my hard drive straight away, can you help?
    Champion:
    Scholar:
  • 209 Answers
Have you tested to connect your HD with another cable (power cable)?
Is it an internal drive or external drive?
The following link is useful to do some tests with DiscWizard.
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4934&p_created=1192999723&p_sid=Csx_ENbj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NDEsNDEmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD05TloyQTQtNTAw&p_li=&p_topview=1
Posted on Aug 20, 2008
My maxtor 500gb usb hard drive is not responding when I plug to my pc, so I can't access to any of my file
hello,
-make sure that the cables from the ext hard drive is properly connected like power if there is and USB -try other USB port -try other USB devices -try other USB cable for that Maxtor -try other computer
the reason why you are doing that is to know if the USB port is broken of if the ext hard drive is not responding.
cheers.
Feb 24, 2011 | Maxtor BASICS Personal Storage 3200...
Correct power supply for maxtor basics 500gb desktop drive
Look for the one that has the following DC output:
12Vdc 2A
Input in Australia is 220-240 Vac correct?
Mar 01, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
How do I crack open Maxtor basics 500GB 2.0 PN 9N22A4-500
If you have "Dropped" this drive & after that it doesn't "GO" any more, then, Undoubtably the "Heads" have "Crashed" into the "Platter" this is Terminal.... Seldom will you "Recover" from this. As there is Physical damage to Both the "Reading Heads" & the "Platter". In saying all that though I guess one has to try, just don't be too disappointed if you don't recover much. anything.
These drives are either IDE or SATA as such they would simply plug into the PC's relevant Data Cables and Power plugs.
Sorry about that. Good Luck. However in all likelihood, the USB interface should be OK, so you may be able to simply obtain a similar Hard Drive and replace it into the enclosure & start anew, being more careful this time, keep it on the floor, less distance to fall....
Feb 10, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My maxtor basics 500gb is saying accsess denided ? and wont let me and any files can you help thanks
There is not much u can do if it wont let u access the drive first try a different computer so we can make sure its the drive and not the usb port on the PC and please make sure that you have confirmed power going to the drive if the drive does not work on another PC then the drive may be faulty if it does then we need to reconfigure your device manager and make sure that you USB drivers are working properly. Marc
Sep 21, 2009 | Maxtor Hard Drive
Drive not recognised
IS IT EXTERNAL OR WHAT
Jun 09, 2009 | Computers & Internet
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Computers & Internet
Maxtor basics 500gb PN-9NZ2A4-500 will not power up. cannot access data on the drive nothingh come up my scren I have the same problem. When i want to acces it , it says drive not formatted ? then i...
Use a differant HDD plug.
You may have a fault in that lead.
It may be that your power supply is too weak to power it, suggest upgrading another 250 watt of your current one.
Jan 14, 2009 | Maxtor Hard Drive
Power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Nov 06, 2008 | Maxtor Hard Drive
Computers & Internet Logo
2,304 people viewed this question
David Payne
David Payne
