Question about Toshiba Satellite A135-S2276 Notebook
Recovery disc problem
I cannot get the recovery disc for my satellite a/135 to complety run. it loads files, copys files, does the now recovering but when it gets to creating crc file at 33% it gives the followin error message. error: 10-fa11-0017, and tells me to shut down... any suggestions?
  • 95 Answers
Yes, you will need a fresh copy of a OS/boot your machine with cd in tray and follow instructions/then place recov cd in tray/go to my computer and right click/cd and explore/look for drivers and install alon with any onther software you need
Posted on Sep 01, 2008
I have display problem, when i try to open laptop, screen doesnot open properly, after 2/3 times shut down it work, what is the problem
If you have a recovery partition, take a DVD disc make a copy of the operational system asp, so if your system crashes you can recover everything to factory setting. Run a full scan for virus's, go to www.download.com Type: ccleaner and run program to clean out junk files, next download smart defrag and run the program to organize hard drive files. Now if you are still having trouble run a full recovery of your operational system to factory setting.
Apr 06, 2012 | Toshiba Satellite A205-S4707 Notebook
Tip
Recover deleted files
This is a tip explaining step by step how to recover deleted data, even if it is already deleted from your recycle bin. Before we start, you need to download the software required to complete this task.
Click HERE to download.
After you have downloaded the software, Disc Digger, all you need to do is to double click on .exe file to run the software. The program will automatically start. Now, for this purpose, I will recover DATA from my Flash drive. Click HERE to read step by step instructions a using a Flash drive.
I will copy some files to my flash drive, format the drive, then recover the Data I formatted. You need to remember that there will be more data recovered than the data I copied, because I have used this flash drive for a while, hence, the other deleted data will also be recovered.
So lets Start!!
For this purpose, I will copy a movie to my Flash drive, format my Flash drive and recover the movie.
Here is what I did:
After I copied the movie and the format was done, I opened Disc Digger, chose the drive on which I want to recover from, and started the recovery. The pictures below will explain the steps I Followed.
To open the application, just click on the extracted icon.
Now, i chose my Flash drive as the drive which i want to recover from, and clicked next to proceed.
I chose the dig deeper option, as this option will recover formated files as well, not just deleted files.
At this point you need to choose what type of file you would want to recover, i chose all file types.
Recovery process in progress. My flash drive is 8 GB in size, the recovery took 5 minutes.
Once the recovery is done, you will receive a pop up, which will state that the recovery is done.
Remember, that once the scan is complete, you need to save the files you have recovered. You need to create a folder in which you want to save the file, I just created a Folder on my desktop. Unfortunately, the name does not recover with the file, so you will need to look through the files recovered and after you have saved the recovered file, you need t rename it.
This software can also be used to recover photos from your SD memory card. Al you need to have is a SD card reader, which plugs into your USB port.
I really hope that you can find this helpful.
Please rate accordingly.
Kind regards
Andrea
on Feb 28, 2010 | Baby Gear
I loaded data from another computer that must have had a virus and now my new toshiba satellite L655-S5153 computer boots up to a blank screen, even in safe mode. the computer didn't come with...
first, recover your files. You will need to use something like this data recovery program.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Jul 16, 2011 | Toshiba Satellite L655-S5153 Laptop
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
I have replaced the hard drive in my daughters A215-S5808. I am trying to recover from the Recovery disk and I keep getting the error mesage 03-EEEE-0000 and press ok to shut down.
The below fix may or may not work but needs to be followed closely.
1. Boot the Recovery disc or HDD image and select System Recovery Options.
2. Follow the prompts until you get to the menu and then select a command prompt.
3. Copy the \zzimages\zzimages directory for all recovery discs to a temp directory on the hard drive (c:\temp).
4. Change to the Bin directory on the first recovery disc and run "tosimagex /apply c:\temp\preinst.swm 1 c:\ /ref c:\temp\preinst*.swm" without the quotes.
That is it. It will take a long time to copy the files since they are large and a long time to run the image program, half an hour on my computer. Also, based on Imagex syntax, it looks like the "1" in the command above might be replaced with another number for models that come with more then one Windows version on the same recovery media.
Dec 06, 2009 | Toshiba Satellite A215-S7422 Notebook
Satellite A-135 Recovery Disc won't work.
Write zeros to the hard drive using the software from the hardrive manufacturer website, then install your windows program
Sep 20, 2009 | Toshiba Satellite A130 A135 Notebook
Wish to make a recovery disk
Toshiba usually ships laptops with recovery cd/dvd sets.
If you have captioned recovery set, make sure to make a backup copy.
If this series no has recovery cd/dvd, must be a hidden partition for recovery in the hard drive. For make a recovery disc find the sotware loaded in the laptop (must be there) and make a recovery disc set. Be aware that some manufacturers limit the use of this particular software (you only can make one cd/dvd recovery set).
In the worst scenario that the recovery partition is no present you must load Norton Ghost v14.0 and make a full backup to one external hard drive (USB) in order to recover te operative system, drivers and software in case of disaster.
I hope this help you to solve the problem.
Posted by MCampos
May 31, 2009 | Toshiba Satellite Pro L350-S1001X Notebook
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
A70 recover disc in A35 Laptop? (Toshiba Satellite)
Recovery disks are model-specific, mainly because they have different devices and drivers. Setup drivers are downloadable, and copied to a CD at an Internet cafe.
May 16, 2008 | Toshiba Satellite A35-S159 Notebook
Recovery Problem
  1. Check you are really using the right CDs
  2. Using another computer with a CD Writer and a blank CD, download this file:
toshdmi10.exe
Run the program, it will explain how to make a boot CD which you will use to start your computer and fix the problem that makes it say Wrong Machine.
Once this is done you can use the recovery cd's again.
Nov 15, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
300 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
