Dvd Tray does not always open - Televison & Video
    Genius:
  • 1,550 Answers
When the tray get open see if you can replace the belt of the charge motor it´s all the problem
Posted on Aug 20, 2008
CD/DVD burner in Compaq Presario 5010NX w/ VistaBasic Reads and any DVD but has problems with CD's. If I load a music CD, sometimes it will open right up and I can play the music. Most times it just...
Microsoft updates may not have the driver you are looking when it is searching for drivers. When you are in the device manager make a quick note to the name of the device and go to http://www.compaq.com/country/cpq_support.html
and see if you can match the device to the driver for your pc. If you are able to find the correct driver and install it and still receive the same results then the drive itself may have a problem.
Mar 14, 2011 | Compaq (CDD480172) CD-RW Burner
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
Apr 03, 2010 | Panasonic DVD-S25
My DVD is stuck in the DVD player and will not come out .
There is always a small pin hole in the DVD tray. Insert a pin through it and press lightly when you feel the resistance. Just slightly. It would unlock the tray lock and the tray would open.
Apr 01, 2010 | Sylvania Dual Deck DVD/VCR
My DVD tray will not open, and with no disc inside the display says 'reading' constantly. Any thoughts?
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. I had to do this on my unit and therefore I recommed leaving a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Oct 11, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
When I press the Eject Button on the Bose 321 DVD Player the tray does not open up. I can hear the sound as if trying to open
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
May 30, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Televison & Video Logo
289 people viewed this question
Top Televison & Video Experts
