Question about Kenmore 98702 Stacked Washer/Dryer
Overfilling Model # 417.98862890 Washer will continue to fill unless I manually turn the load selector to a lower level. Sometimes it will take a few times to make it stop filling. I'm thinking it is the pressure switch as I am able to get it to stop filling. Looking for assistance in the procedure to replace the switch. Thank you
  • sknezevic Aug 20, 2008
    Thank you for the info. After taking the front panel apart, I found a few coins in there. One was on top of the switch and may have been shorting out a connector. Cleaned everything out and gave it a test run. It worked properly on all sizes. I will continue to monitor it to see if the problem returns.
    Thank you again for the prompt reply.
  • madurkin Sep 13, 2008
    My machine overfills too. I replaced the pressure switch, but can't find the other end of the clear hose. Is there an easy way to access it? I assume it reaches in the tub's outer case, but do I have to take the whole machine apart to access it?
  • 5,911 Answers
Have you checked the pressure switch to ensure the rubber air hose is still attached? It is common for the air hose to come loose, or develop a small hole or crack and give the same symptoms. This may save you from having to purchase a new switch. On your model washer, the switch will be located behind the load level selector knob behind the front panel. To access, follow these steps:
1. UNPLUG the unit. There are still dangerous voltages behind the front panel with the unit shut off.
2. Remove the small panel that is angled above the washer lid and just below the operator panel.
3. Remove the cover plate under the panel by removing the series of screws holding it in place.
4. At the bottom edge on each side of the operator panel is a small screw. Remove these screws and the panel should lift up slightly, then come off, exposing the components behind it.
Look for a clear rubber hose. It should be attached to the pressure switch on a small air fitting. If not, reattach the hose and place a small zip tie around it at the point where the hose fits over the air fitting. DO NOT over-tighten, as you can break the air fitting on the switch. Just make the zip tie snug enough to keep the air hose from coming loose again.
If the air hose is in place, inspect the entire length of hose for cracks or holes. If you find any holes, I would recommend replacing the hose instead of trying to seal it. That way you avoid the possiblity of tape or sealant leaking and causing the unexpected overflow again. You can find air hose at most hardware or automotive repair stores.
If the air hose doesn't seem to be your problem, check to make sure all the electric connections are attached and making good contact on the switch. If you check all the preliminary items and everything checks good, then you may assume a pressure switch malfunction. A replacement can be found at searspartsdirect.com under the "Control Panel" heading as item number 5 (part number 134493500). I hope you find this information helpful. Let me know if you require addtional assistance.
Posted on Aug 20, 2008
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
My Kenmore frontload washer Model 417 sometimes sticks in the fill cycle and will not advance.It will stay that way for hours just running water.If I advance the knob just a bit it will continue as...
Your water level sensor, or perhaps the selector switch itself, is faulting on you.
Next time it sticks on a medium load, see if you can move it to a light load. If it sticks on a light load, goto medium load. In both cases, if the washer comes back to life (starts to agitate or resumes filling), then your selector switch is out.
If rotating the selector switch doesn't seem to do anything, then your pressure switch / level switch is faulty.
Selector switch and pressure switch are both located in the compartment where the controls are mounted.
Sep 10, 2010 | Kenmore Washing Machines
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
The washing machine will overflow, flooding water onto the floor. Flooding has happened 8 times, and it attempted to do it about another 5 times (I stand there and watch it and turn off the water supplies...
ive included a solution to a similar problem that i solved earlier this week, i hope you find this helpfull...
I am assuming this is a top load washing machine.... the load size selector button has a hose attached to the back of it. This hose goes down to an overflow box mounted to the side of the tub. This tube often gets clogged and the machine cannot tell where the water level is. 1) dissconnect the tube from the level selector switch and ( w/it unplugged ) attach another tube to it and blow into it. you should hear a clicking sound. this means your level selector switch is functioning properly. if it does not click then it needs to be replaced. 2) dissconnect the tube from the level selector switch and ( w/it unplugged ) blow into the tube and you should hear air going into the tub, ( this is best performed with water in the tub ( bubbles ) )....hope this helps
Asker's Testimonial " Thanks rdrsp. When I took the control panel off, I found that the tube had fallen off the control valve. I put it back on with a band clamp. " - bill_marv460 "
Oct 22, 2009 | GE WVSR1060A Top Load Washer
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
Kenmore 90 model 110.20912991 wont stop filling with water
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
Jan 27, 2009 | Kenmore 15864/15862 Top Load Washer
Wont run unless it is a mid sized load.
You either have a problem with your water level selector switch or you have debris in your tube.. if you know how to take your washer apart you can check the tube... or if you can take out the console where the water level switch is unplug the tube from switch.. blow tube and plug back onto switch.. see if that works.. if the tube has a crack replace it.. good luck...
Jan 21, 2009 | Maytag Legacy Series Top Load Washer
Kenmore 90 series heavy duty washer
If it fills up to normal level on other settings then the water selector switch is bad.
Look at the back side of this switch and you should see a tube connected from the switch to the lower part of the tub. Take the tube loose at the switch and blow through to check for any blockage. Look at the tube for holes.
Nov 14, 2008 | Kenmore 22422 Top Load Washer
Re EW1200i : drum keeps filling with water
is it overfilling? if so you have a problem with the pressure side of the system and it would need cleaning out.
May 26, 2007 | Electrolux EW1200i Front Load Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
120 people viewed this question
Sal De
fordexpert
Robert Rankin
