Question about Sanyo DP32746 32 in. LCD Television
Will it work on 50hz?
Overseas we use transformers to go from 220 volt down to 110. Hz though remains at 50hz instead of 60hz. Will this affect operation?
  • 105 Answers
Best to call customer service 800-877-5032. if under a warranty would not want to lose it.
Posted on Sep 22, 2008
Want to use this on 220v aussie supply to power 1947 221 lionel train loco Suitable?
ohh no that id not try at all , one can first use a power converter that one can buy off many online sources to convert 220 volt down to 110 volt then to transformer this will be safe 4 unit, the 50HZ to 60 Hz doesn't matter to much as well unless one plans on using the lionel sound generator , then its not gonna sound to spry as it will be a bit slower !!
Jun 16, 2015 | Lionel O Train Transformer 6-14198
I want to buy a brother pc-420 in australia, how do i achieve that?
I suggest to ,, on the internet look for sewing machine shops in your town in australia, & even look in the phone book in the yellow pages
do you have a hancock fabric in your area? they have sewing machines & sergers
Feb 11, 2012 | Brother PC-420
Bought a singer from the state but cannot be used in australia what should i do?
If it is an electronic or computerized machine, you are out of luck. USA has 110 volt 60Hz current, Australia has 220 volt 50Hz. A transformer can change 220 to 110 volts, but it cannot change 60Hz to 50Hz.
Sep 21, 2011 | Singer 4423 Sewing Machine
I just bought KitchenAid Artisan Stand Mixer KSM150PS with 110v and 60Hz online and received it today and realised I cannot use it on australia. Can I use transformer which I can get here to convert 110V...
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
We have a Sony Bravia 2 years old from USA (110 vault) and have now moved to Singapore (220 vault). Can we plug this tv in or do we need a transformer?
you would need a step-down transformer from 220 volts to 110 volts. Also you need to consider the Frequency as USA uses 110-115V 60Hz and many countries around the world use 220-240V 50Hz. In addition you need a physical wall plug adapter so you can plug the power cord into the wall. These are not very expensive but get the proper kind. Generally it is a good idea to buy a TV over there which is more compatible.
Apr 03, 2011 | Televison & Video
Does not work on 50Hz kenmore elite dish washer
If it was built for 60Hz AC power (American), it will not work on 50Hz power. The Hz, is the number of cycles per second, the electricity makes. If your motor & controls are wired for 60cycles, they will not get the proper electrical supple to work on 50 cycles. AC voltage goes from neutral to positive to neutral to negative to neutral, (one cycle) according to the country you are in. Some countries also use 230 or 240 volts, instead of 120 volts.
Sep 10, 2009 | Dishwashers
60hz to 50 hz
No need to worry about that. The direct drive on these turntables will adjust for hz setting automatically.
Jan 10, 2008 | Technics SL-1200MK2 Turntable
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Technics SL-1200MK2 Turntable
Convert 110 volts to 220 volts
Hi, 1. To convert 110 to 220 - use a step down transformer between your mains and your unit with the watt rating equal to or greater than required by your unit; 2. If I got your brand/model right, I believe it is capable of either 50 or 60 Hz. However, if for some reason you still would want to convert convert 60 Hz to 50 Hz, it will be difficult and technically complicated. At best that I can offer is for you to get hold of an AC-DC-AC converter with the following specs input 220VAC/50Hz output 110/60Hz. 3. NTSC to Pal N would require complicated circuitry and if ever available would be expensive. Past experiences have shown me that any color conversion is not that satisfactory. It may be to your advantage to return the unit and have it replaced with a region correct model. Good luck and kind regards.
Aug 20, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Sanyo DP32746 32 in. LCD Television Logo
61 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
