Question about Sony Car Audio & Video
I have no remote for a sony car stereo after buying sec ond hand car,is there a way to use any other type of remote or would one of those ones you can get that do a multitude of different appliances work?Any advice would help
  • 10,594 Answers
Please mention model number of your Sony car stereo to find its remote.
Posted on Aug 20, 2008
SOURCE:
I have a urc r6 and want to program Sony Stereo Receiver STR SE 501
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 07, 2014 | Televison & Video
Need remote control programming codes
I assume you have purchase a universal remote control...if the programming codes for your Sony STR-DE675 receiver is not listed in the remotes code guide, then you purchased the wrong type universal remote. Make sure you get a universal that does stereo equipment or check eBay for a reasonable price on the original.
Jan 07, 2014 | Sony STR-DE675 Receiver
Only my source button works on my sony cdxgt340 car stereo
I have the same problem, but find out that someones remote works. I find an original remote RM X151 on eBay for $4.00
And this works !!!! I guess a lot of Sony owners have the same problem, but if you would like a quick fix without going very expensive, you can just buy this remote and hope will work as well for you. Good luck.
Nov 22, 2013 | Sony Xpl?d CDXGT340
I lost my rmum242 sony remote for my stereo receiver if i buy another one will the new one work? or do I have to have the origianal one?
A universal remote control may allow some, but not all, functions to be performed. It might be worth the extra expense to buy an exact (or functionally equivalent) replacement remote
Jan 10, 2013 | Sony Rmu242 Remote Control
I bought tv Sony LCD 32
You have to open your TV to do this work. The remote sensor can be located just behind the infrared window at the front panel of the TV. It is a three solder terminal component, and can be bought from most of the electronic spare part selling shops at your tow. It will have a number printed on its side, which should be noted, when buying a new one. So many types are there in the market and you have to be the sensor you want to buy in you hand when you go to buy one. for your reference, picture of some types are attached here.
Aug 25, 2012 | Sony KDL32L5000 32 in. LCD HDTV
Hi i'm trying to programme my sharp stereo with a sony rm vz220 remote control. But can't get the correct code. The only code that i got was 60048. But it does not work.. Help plz..
According to the Sony Support site for this remote, receivers are NOT supported at all. Additionally, only a handful of codes are available for Sharp electronics. They are for the following devices:
Blu Ray, CD, DVD, DVD Recorder, TV and VCR.
All the codes used for the devices above are:
12250, 70034, 70037, 70180, 10630, 10675, 12250, 10675, 00818, 60048 and 60848.
You could try these codes one at a time and possibly gain some remote control capability - but that would only happen by chance. The codes above are the ONLY ones built into the RM-VZ320 remote for Sharp brand products, and if none work for your equipment, Sony says you should use your original equipment remote to control it. Not very helpful.
You can either do as they recommend, buy a pre-programmed remote that supports your device, or buy a pre-programmed remote that supports "learning". Learning remotes are universal in that the products not built in to the remote can be learned by holding the original so it points at the learning remote and pressing function buttons so that the learning remote "records" the buttons pressed on the original. It can take some time to do this, but you are assured that the remote will work with you device. Of course, you must have the original remote to do this though.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Sony RM-VZ320 Remote Control
When i turn off my stereo, it turns back on in three seconds.i don't have the remote anymore. how do i get the stereo to stay turned off.i pushed the AUX button-but that didn't do anything and my step...
You can buy a universal remote that should work with your stereo - but it may not solve the problem.
If the latching system that hols the OFF setting is broken the remote software will probably not overide it,
Ask your step father to put his hand in his pocket to help you get a new/better one - everything changes in time!
Feb 26, 2011 | Panasonic SC-AK100 CD Shelf System
Hello I have a problem in which I cannot access the menu on the CD player because I have no remote control. Is there any button pressing sequences to access the hidden menu without a remote control? It...
The most simple solution is buy a cheap sony universal remote. If there both Sony devices, there is no programming required. Just make sure the remote you buy HAS a menu button on it.
Apr 03, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Need a battery for my hct remote for stereo
Go to "manualsonline.com.
Select "RCA"
Fill in model number in table on the left hand side of screen and select "ask a member for help".
Type in problem and wait for a reply.
Dec 21, 2009 | RCA RCR660 Remote Control
Car Audio & Video Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
