Question about Fuji Cameras
Finepix S6500 strangelines and washed out pictures as if massively overexposed. lines look like magnetic fields or something, video function OK.
  • Fuji Master
  • 19,396 Answers
Ooks like you have a defective CCD , try resetting camera to factory first.
Posted on Mar 02, 2009
  • Ginko
    Ginko Mar 02, 2009
    washed out pictures as if massively overexposed, are not a setting problem.
    You can reset settings to factory, but the problem is either defective lens, or most commonly a defective CCD sensor.
    The camera must be fixed at a repair shop to fix this.
  • Fuji Master
  • 13,434 Answers
One solution is to get a photo editing program to your computer, youshould be able to adjust the pictures and fix this problem on thecomputer.
heres a tutorial for photoshop
http://www.photoshopsupport.com/tutorials/jennifer/fix-overexposed.html
SOURCE:
PLEASE EXPLAIN WHY LINES APPEAR ON VIEWING SCREEN AND ALSO ON SAVED PHOTOS. MANY THANKS. IS IT POSSIBLE THAT I MIGHT HAVE PRESSED A WRONG BUTTON?
Lines appear on your photo's because the shutter is either stuck or is not firing completely over the lens when you take a shot. You will either get overexposed pictures (white out) or these lines like it is taken through a blind.
The most common cause for this is moisture residue building up on the shutter leafs over a period of time.
An easy way to verify this is to use the video function. It should be perfectly fine as this function does not use the shutter. This will also eliminate the sensor as the cause of the problem.
Jan 11, 2010 | Fuji FinePix F470 Digital Camera
Hi, I seem to have a problem with my Finepix Z1 digital camera. When I take a shot it seems to work ok, and the initial review image seems fine as well. But when I go back and review the image on the...
The clue is with the video.
The video function does not use the shutter. Lines on photo's or over exposure is due to the shutter not closing completely over the lens when you take a picture.
It will require cleaning which means opening up your camera and accessing the lens unit
Oct 28, 2009 | Fuji FinePix Z1 Digital Camera
Fotos are white
Try the video. Is it ok?
Adjust the zoom so the internal lens is up close to the outside lens. Now, look into the lens at an angle so you can see into the lens without reflection. With the flash "off" so as not to blind you take a picture and watch the shutter close over the lens. Did it cover the lens? If not then something is obstructing it or there is an electrical failure with the electro magnetic switch operating the shutter.
Apr 24, 2009 | Fuji FinePix S6500 Digital Camera
Help me i have lines on my pictures and i dont know what to do!!!
Your shutter is not closing correctly. only solution is to strip it down and clean the shutter. The lines are due to over exposure. pictures in daylight will appear too bright. The video function should work ok as it does not use the shutter.
Apr 15, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Help!!!i lost the software that came with my fuji fine pix S6500
hi.
here's the direct link for the S6500fd photoshop plugin download from adobe. photoshop should open raw after you've installed this:
http://download.adobe.com/pub/adobe/photoshop/cameraraw/mac/3.x/DNG_Camera_Raw_3_7.dmg
Here's  the adobe downloads centre link in case you need to check up on everything & the installation instructions.
http://www.adobe.com/support/downloads/thankyou.jsp?
Cheers Andy.
Mar 25, 2009 | Fuji FinePix S6500 Digital Camera
Lines across my photos
Nothing to do with any chips being faulty.
The clue is in the video....
The shutter has become fouled.
Unfortunately this is a major strip down to clean the shutter
Jun 11, 2008 | Fuji FinePix F460 Digital Camera
Cannot copy from finepix s6500 to my computer
Are you using a USB card reader. If not you should get one.
It's quicker than using cable to transfer files, and they are getting cheaper. Just make sure you get one that reads XD cards.
Mar 25, 2008 | Fuji FinePix S6500 Digital Camera
S6500fd,s6500 lens types.
The lens is a 28-300mm zoom and is permanently affixed to the camera (s6500fd).
The only extras are listed here:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/d-slr-long-zoom/finepix-s6500fd/OptionalExtras
Dec 13, 2007 | Fuji FinePix S6500 Digital Camera
Attachments?
There are loads of lenses on ebay such as 58mm 0.45X Wide Lens FOR Fuji S6000 S6500 fd BKs.gif I think any will work provided they are 58mm
Nov 14, 2007 | Fuji FinePix S6500 Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
