Question about Dryers
Does not heat
Dryer works but does not heat heater wont work
cleaned filter and heat exchanger
    Genius:
  • 2,920 Answers
Heating element or limit switch is out they are in the back of the dryer
Posted on Aug 20, 2008
After every load, the dryer lint trap is wet and there's water condensation on inside of the glass door even days after use. I've thoroughly cleaned the ducts and the lint filter as well as inside where...
Is it gas dryer?
If it is might be problem with the heat exchanger, Water is one of the by products of combustion.
By chance do you have a Carbon Monoxide sensor?
Easy way to tell if a cracked heat exchanger is the problem.
Other thought I have is the dryer heating up when its drying, if the heater isn't working and you are throwing wet clothes in there that could be part of the issue.
a couple thoughts anyways
Aug 23, 2013 | Kenmore 7.3 cu. ft. Electric Dryer w/...
My Pentair Mastertemp shakes and rattles, then cuts off after about 15-30 seconds of running. I called a pool co. and they told me to replace the water regulator valve, which I did. The same problem is...
When a heater starts rattling and shaking it has nothing to do with the water regulator. Some of the most common possibilities are as follows:
1. Very low water flow. If the skimmer or strainer basket on the pump or pool are clogged, or the filter is dirty, or the pump is old and not working properly, you can get just enough flow to activate the heater, but not have enough flow to do it safely. When there is too low of water flow, the water inside the heat exchanger evaporates into steam which creates pressure inside the exchanger which cannot be released, therefore making the heater "jump" or "shake" al over the place. This fix is easy if this is the case, fix the flow problem.
2. Hole in the heat exchanger. When heat exchangers start to fail, they get small holes in them letting air into the system. When this air gets super heated it expands and creates pressure just like the above situation (kinda). This will also create the shaking.
3. Completely clogged heat exchanger (inside the exchanger). If you fill off a well system, or have high metals and minerals in your water, these metals and minerals will attatch themselves to the inside of the heat exchanger thus clogging it and reducing the water flow through the heater to just about nothing. There are 3 cleanout plugs on the heat exchanger so that it can be regularly flushed. This should be done at least once a year.
4. Clogged heat exhcanger (outside the exchanger) This is the least likely, but if you are getting a bad burn on the heater due to not getting annual services, the heater will soot up, prohibiting the natural venting capabilities of the heater, and trapping ALL of the flames heat on the exchangers bottom. With nowhere to go , once again, the exchanger is super heater and pressure builds up enough to shake rattle the heater.
Sorry there are so many options for this, but all signs point to this heater needing a serious cleaning inside and out. It can be done by you, but should probably be done by a service tech.
If you have more questions, contact me @: adamh@newconceptchem.com
Jan 21, 2011 | Pentair 460730 MasterTemp Heater 200BTU ...
My whirlpool awz7303 is not get hot so there for my clothes are not drying. i have checked the filter, water container and the heat exchange they are all clean and empty but the filter indicator light is...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Whirlpool AWZ7303 Electric Dryer
Dryer has no heat--even though lint filter and heat exchanger are clean; the light is also off, but the tumbler turns normally
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 04, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
The 1998 durango heater works but wont heat! what is wrong with it?
Could be a heater core plugged or improper adjustment on the heat exchanger cable. Turn your heater on high and go under the hood and feel the two hoses on the passenger side coming out of the firewall. See if both hoses are hot when the engine is at operating temperature. If they are both hot then there is probably a problem with the cable adjustment or heat exchanger door not functioning right. If only one hose it hot then your heater core is plugged which means changing the heater core or you can take it to a radiator repair facility and they can hook up to your vehicle and can sometimes clean your heater core. We have had success at doing a bunch of plugged heater cores this way. Worked in most all cases.
Dec 10, 2009 | 1998 Dodge Durango
Dryer doesn't dry clothes. seems to run on low heat.
Make sure dryer is unplugged. Take the back off and you will see two heater exchanges and probably the element. One of those heat exchangers is for hot setting. When you find out which one go to nearest electrical shop with it and order. I reckon thats what your problem is. I've changed mine and everything was alright.
Oct 04, 2008 | Frigidaire Dryers
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
