Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Usb port not working
I have been trying to solve the problem i hav lately,except my digi cam and the game pad every thing else that i use i.e. pendrives and card readers are not being recognised.i have been trying to solve the problem from everywhere,though iam not a technician but i think i have exausted all the steps and solution given on the net by people,if there is a possibility that the usb is failed or malfunctioned then in that case can it be repaired,without me buying a new motherboard.
it is intel p4.2.66GHz
    Genius:
  • 1,226 Answers
i read your problem. so all your stuff connected to usb port is not recognize or not detected at all?
If the pendrive and other stuff and not detected or not attempting to install then the usb ports got faulty. however if this attempting to install the driver. then you need to install the drivers related to your hardwares.
Vista OS is still updating the system to resolve the issue. Go to your hardwares manufacturer's website then download the latest driver for vista.
may this an initial help,
melnavz
Posted on Aug 26, 2008
  • 781 Answers
If you have Vista check M/soft site for bulletin 940199
Vista has a habit of losing USB ports and there is a fix for it
Posted on Aug 23, 2008
Lenovo Touch pad Stopped working
If you're positive you didn't unplug or rip anything while installing new USB ports, trying checking/updating or rolling back the drivers for the touch pad. Installing new USB ports could have mis-configured something and disabled or modified your drivers for the touch pad.
Mar 12, 2014 | Lenovo IdeaPad Y550 Notebook
Can I hook up a 4 port usb hub backwards?
well if you plug the usb cord that powers it into some thing else that has a usb port that is running electricty through it such as a pc you should be able to plug in any thing that needs charging with a usb cord that will go into the 4 ports . so i guess it should work i know it wont mess anything up so go ahead and try it. also if you got a usb wall charger that can hold a usb cord you can plug the 4 port usb hub into that and it will work like a charger for things with usb chargers.
Dec 17, 2012 | Video Game Consoles & Games
I hav qwest yrless trying 2 play ds i wfi it says
find out your WI-FI USB ports code then it should work.
Oct 07, 2009 | Nintendo DS Console
USB Device Not Recognized
try downloading the drivers from sony first http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C116935&fes=true&mdl=DSCW5 that is if you have already downloaded the proper usb drivers for your system in which case other usb device are still working also it is possible that the usb port itself has gone bad or is in conflict with another driver assuming your using windows to check this you can start by telling me which version of windows you are using but more than likely the proper camera drivers will solve the issue
Apr 26, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
360 dance pad not working on xbox
try plugging your usb connector into the usb port located in the back of your xbox 360 next to the power cable coneccion
Mar 31, 2009 | Konami Dance Revolution DDR Original Dance...
Usb port
Have you installed the driver for your digi cam? usually you need to install a driver for it to work on your system.
check your digi cam's manufacturers website for downloadable drivers and install it in your laptop.
hope this helps, please rate.
Feb 07, 2009 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Computer not recognizing web camera
The only other thing that I would suggest you try to do is (if possible) goto another PC or maybe a friends PC and plug the web cam in. If it does the same thing then the web cam no longer works. If it does work, then you may want to try another USB port on your PC.
Jan 23, 2009 | Logitech Webcam
Satellite a135-s2386
Resetting your USB Controllers I'm going to assume that you're running XP (home or pro). Recently I had to refresh my USB ports. This is the sequence I used.
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Sep 27, 2008 | Toshiba Satellite A135-S2386 Notebook
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
102 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
