Question about Audiovox Televison & Video
We have an audiovox movies2go single dvd system installed in the interior roof of our car. The picture display on the system is not working. You can play a CD in the unit and you can hear it, but not a DVD. You can also see the radio tuning channel numbers for the wireless headphones, but no picture or sound from the DVD. Any suggestions?
  • 7 more comments
  • whtchathink Aug 21, 2008
    The model is a drop down screen unit (MMD85)
    A question about cleaning the lense. How do you do that exactly? Is it a disc that you use to clean the DVD player? Not sure if we need to take the unit apart to clean it or if we need to use our cleaning disc. Please advise. Any other comments welcomed as well.
    Thanks!
    It doesn't seem to play the DVD at all. You can't hear any audio from the DVD and the screen is black - no picture. If you put a music CD in, it will play and we can hear it fine.
    Since this unit is "installed" in our car, checking cables & wiring might be a challenge - where do I start?
    I do not know what a hand brake wire is - please advise or offer other suggestions.
    Thanks for the suggestions. What is the best way to check the cables on an installed unit? Where are things connected generally?
  • whtchathink Aug 22, 2008
    I am not able to see new comments. How do I fix this?
    I never accepted a solution from any of the experts and now I am not receiving any additional advice. My tag is incorrect/incomplete. It's a video and audio problem. None of the answers seemed very specific to my problem and when I asked for additional comments from the experts no one has responded. What now? Please change the status of my problem as not solved so that I can receive additional advice. Thank you!
  • whtchathink Aug 25, 2008
    To check connections in a DVD unit that is installed in our auto, where would most connections be? The unit is a drop down screen from the interior roof of the car. Do I need to dismantle the unit on the roof or should I look under the dashboard?
    Master:
  • 788 Answers
Get to the product page here: http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13880&langId=-1
Click on the "find a manual" link and get the owner's manual and the instalation manual.
The installation manual will show you have to remove the unit from the roof. But I don't think you will have to do that.
Make sure the source selector is on the DVD setting for playing DVDs.
The unit also came with an auxillary AV cable. You could use it to test with an external DVD player or any other video source. Doing this will test the screen, if you get video from the AUX source but not the unit's built in DVD player then there is something wrong with the unit's drive. If you still don't get video from an AUX video source then you know there is something wrong with the screen itself.
You can also press the SETUP button on the remote to bring up the menu, if you don't see the menu then the screen is probably shot.
If you determine that the screen is faulty you have a few options. If it's under warranty contact AudioVox about getting it repaired. You can send it to Audiovox for repairs if it's not under warranty but be prepaired to pay. Your third option is to purchase a new unit.
Also make sure you are putting your movied in the unit's DVD slot drive and not into your car's stereo. The screen has a built in DVD player. I know you are probably already doing that but I just thought I'd make sure.
Posted on Aug 25, 2008
  • 2,071 Answers
The flex connection from circuit board to the LCD screen maybe loose connection or breaks or cut,if ever only a loose connection you can re solder it...
Hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 30, 2008
    Your problem is LCD screen because the audio is good.There something wrong to your screen,you better check loose connection or cold solder joint,Unfortunately, the solder connection alone is often used to make both the electronic as well as the mechanical connections. Solder is made up of 60% lead and 40% tin, so it can not be expected to do the mechanical job for long. Designing larger circuit board traces does help to increase the surface area as well as strengthen the pad and the trace leading to it. To minimize stress to the soldered connections, physically heavy components — as well as all frequently used switches and connectors — should first be mechanically secured to the PCB.
    Figure 1 has been magnified and enhanced to show four solder pads that have potentially cold joints. Counter-clockwise from lower right, the initial problem isn't so easy to spot, just a slightly "grey" or frosted joint, with each counter-clockwise joint getting progressively worse. This is what ultimately happens when a little pressure is applied over and over again via both mechanical stress and repeated heating and cooling cycles. This would be the case in any studio and especially on the road. Once in this state, the connector could easily be removed from the circuit board with little effort, without soldering. Sometimes the solder connection holds up, but the junction of the PCB trace and the PCB pad will break.
  • LORETO LACARON
    LORETO LACARON Sep 01, 2008
    Did the solutions from all of us experts solved your problem if
    not then let us know the current updates so all the fixya experts can
    assist you further.
  • 6,487 Answers
I believe you can find it under the dashboard, so try checking under dashboard if you will be able to find it there, then you could continue the process..
Good luck........
  • 813 Answers
U have to go with a professinol service man
Posted on Aug 24, 2008
    President:
  • 624 Answers
I agree with Abrsvcs about the lens cleaning. it rarely works and there is only one lens in these units. I have been repairing car and home audio for over 18 years and have never seen any DVD player with two lens's.
But your problem is most likely the pick up (part with lens in it) being weak, or on many DVD players that will play a CD but not a DVD it can also be a memory IC.
Both of these options will require a service center to fix it. It is not something that is an easy fix for the end user.
Posted on Aug 21, 2008
  • 4,234 Answers
First of all there is only 1 lens on the optics assembly. The lens cleaner disc that you can purchase rarely works. Carefully open up the unit and clean the lens using a cotton swab and alcohol. A DVD requires more laser power than a CD to work properly. It is a common symptom for optics that are starting to fail that CDs will play but DVDs will not. If the celaning with alcohol does not resolve the problem, the optics block will need to be replaced.
Dan
  • ABRsvcs Aug 25, 2008
    You r fundamantal problem is that the digital information is not being read from the DVD itself. This effects both audio and video. Basically what happens is that the disc (either CD or DVD) contains digital informatio (ie. ones and zeros). These are read by the optical block and sent to a D/A converter (Digital to Analog) which is then processed as either video or audio information (picture and sound). If the initial digital stream is not present, no video or audio. As I stated before, the level of laser required for teh reading of a DVD is much higher than for CD. It is common for CDs to play but DVDs to fail when the optics are failing.
    Your unit needs to have the optical assembly replaced. No amount of cable changing or adding of ground wires or resets will fix it.
    Bottom line: Bring the part that accepts the DVD to a servicer for repair.
    Dan
    Master:
  • 623 Answers
Loose video connection,disconnect check and reconnect properly
good luck
    Scholar:
  • 163 Answers
Make sure your connection strip cable to display is well fitted.
    Master:
  • 848 Answers
Try this if you just ground the hand brake wire by securing a section of exposed wire with one of the main body screws
    Genius:
  • 1,665 Answers
You must first check for any loose or bad wire harness connection
  • Audiovox Master
  • 19,396 Answers
If you see on the car DVD display that it is playing DVDs and disk is running , but you get no picture on displays, then it is a wiring problem with display, check RCA cables and connections to LCD displays and eventually replace or refit cables.
  • 2 more comments
  • Ginko
    Ginko Aug 21, 2008
  • Ginko
    Ginko Aug 21, 2008
    Try first cleaning lens , as suggested by Jaime, I did not know your unit had separate lens, probably he is right, you can buy a DVD cleaner kit at Circuit city or at any local electronic shop.
    To check wirings you will need to take off the unit and check connections at the back, then access connections to display and test cables, it is strange that thy are gone alltogether, probably is the lens.
  • Ginko
    Ginko Aug 21, 2008
    Thanks for the info tech48 I was starting to get confused on this, I haven't seen any double lens unit either. I think it would be quite a mess to control the two pickups in such a little space, but you never know.
  • Ginko
    Ginko Aug 22, 2008
    Yep, pickup with two lens does exist then, by the way this does not make much difference, as a dirty dvd lens can start having difficulties in reading some kind of dvds and read certain others, I assume th can happen also that a unit with dirty or defective lens can end up reading CDs only.
    To the user start trying a lens cleaner product, then you will proceed with wiring check on displays and the rest.
    Check also your in car DVD display out settings.
    President:
  • 1,450 Answers
It will not play a dvd at all? or plays but cannot see it?
  • 1 more comment
  • TripleTauto
    TripleTauto Aug 21, 2008
    I am sure you habe tried different dvd's by now. You do not need to take apart the system to clean get a disc cleaner it is a cd with brushes on it and a cleaner.I believe you have a defective lens usually dirty lens will show bad picture or disc not readable.Also try and loosen the mounting screws just a little.I have seen numerous mobile units quit working cuz they were overtight.It is a no cost thing to try.
  • TripleTauto
    your unit is an all in one unit so only wires running out of it are the power/ground these are good since you can power up. you can take unit loose and see if a cable has come unplugged but it is unlikely
  • TripleTauto
    you do not have a handbrake wire on this unit he is referring to in dash models that by law can only play when park brake is applied
  • 2,326 Answers
This combo devices have two lenses, one to play CDs and one to play DVDs. It looks like the lens that plays DVDs is defective and will need to be replace.
Try using a lens cleaner. If the lens cleaner does not work, the lens is defective.
If your device is less then a year old, still under manufacturers warranty.
Let me know if you need further assistance.
  • 1 more comment
  • Jaime Hernandez Aug 21, 2008
    The lens cleaner looks like a CD, radio shack, best buys should have them. The instructions on how to do it are included with the CD cleaner lens.
    @ tech48
    Check this link
    I should have said some devices. There is always something new to learn even after so many years.
What does "NO REMOTE DVD" mean on the entertainment system screen?
Either the power to the DVD unit is off for some reason or the signal connection to the entertainment unit is loose. It sounds more like a power issue, since the ent. unit senses the DVD but can't access it. Have the dealer check it out.
Mar 01, 2015 | 2005 Lincoln Navigator
Audiovox 8
So you're saying that already tried a lot of DVD but none of them is working? but this was working fine before is that right?
Aug 26, 2008 | Televison & Video
What kind of game disc do u use in a VOD 102 roof mount player.
There is no "game disc". The unit comes with a wireless game controller. When switched on a list of ten games is displayed on the screen.
The other route is to connect a seperate gaming unit through the inputs located along the edge of the unit, select source until the gaming device logo appears on the screen, begin paying.
Sep 07, 2012 | Audiovox VOD102 Car DVD Player
My dvd does not work its the wrong region can i
Unfortunately, it is not possible. it is however possible to get a region-less dvd player.
Aug 18, 2009 | Audiovox Car Audio & Video
Movies2go MMDV70C dvd player doesn't work
Look here for manual:
http://akamaipix.crutchfield.com/Manuals/220/220MDV70C.PDF
Feb 19, 2009 | Audiovox MMDV70CB Car DVD Player
Audiovox DVD overhead Monitor
the power supply amperes might be too low try using car batt as your power source
Nov 09, 2008 | Audiovox VOH8512 Overhead LCD Monitor Car...
No picture
If this is connected to a VHS or DVD player or roof antenna, when problem occurs Check to see that the video in to TV cable is tight. If so you my need a new cable
Aug 14, 2008 | Audiovox AVT-1475 13" TV
Dvd -no picture
Sometimes the displays can't be sent to another tv or monitor. Make sure that isn't turned on. Sometimes there can be a short in the wiring if your unit folds up to play like a notebook computer. You can try moving the screen back and forth and see if the picture changes. If neither of these solutions work, contact audiovox and see if it is cover under warranty.
Here is the website:
http://www.audiovox.com/webapp/wcs/stores/servlet/contact_us.jsp?type=nprev&catalogId=10001&storeId=10001&categoryId=874323&langId=-1&page=&urlString=&productId=&brand=
Jun 30, 2008 | Initial IDM-1731 Portable DVD Player with...
Televison & Video Logo
147 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
