60.2 printer error on an HP 4200N - Office Equipment & Supplies
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm...system level issue..this puppy under warranty?
Posted on Aug 20, 2008
3 Suggested Answers
  • 1570 Answers
SOURCE: Hp laserjet 4200n has an
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Posted on Dec 08, 2010
muntejaya
  • 10421 Answers
SOURCE: My HP LJ 4200n printer
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__9iujgt4
Posted on Feb 26, 2011
Error 59.0
Brain stopped when I answered this last night. This is a fuse failure error. Most likely the heating element has failed, there is a small chance that either the ECU or DCA are bad. I would try another fuser if you have access to one.
Jun 23, 2016 | HP LaserJet 4200n Printer
Definition of the printer 4200n
not sure what you want to know.4200n is the model number with the n denoting networked.
Mar 28, 2014 | HP LaserJet 4200n Printer
My Hp laserjet 4200 printer error is 53.10.03
Memory DIMM failed RAM test. Probably needs to be replaced.
Sep 22, 2011 | HP LaserJet 4200n Printer
Hp laserjet 4200n has an error code of 49.4c06 service error what do i do to fix this?
Go to START MENU
Choose RUN
Exit
Go to C drive
Click show content
Choose spool folder
Choose printer
I hope it helps you
Dec 08, 2010 | HP LaserJet 4200n Printer
What is the replacement procedure jetdirect card hp 4200n? Does anything need to be reconfigured after the replacement?
You may have to reenter the IP address sub net etc. One of the easier things to replace... -Carl Hinesburg Vt
Oct 14, 2010 | HP LaserJet 4200n Printer
I have an hp 4200n that picks up an extra blank page when i print a menu map. the paper (blank page only gets up to the delivery assy past the fuser, no jam error). this happens when i print it from tray...
Hello, you must clean separation roller whit wet cloth or alcohol. Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean Good luck. P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Oct 15, 2009 | HP LaserJet 4200n Printer
My hp LaserJet 4200n prints multiple pages when only one is requested.
This can happen with a driver issue check what driver you have installed and if it is a PCL6 driver try using a PCL5 driver and see if your issue is resolved.
Sep 23, 2009 | HP LaserJet 4200n Printer
Hp laserjet 4200n printing blank page
Hi!
Please see the following link to resolve the issue you are facing with--
HP Laserjet 4200 Printer
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 27, 2009 | HP LaserJet 4200n Printer
New LJ 4200N Install
simply connect the rj45 cable and create the printer using hp network printer software. you can download it from the hp website
May 30, 2008 | HP LaserJet 4300n Printer
519 people viewed this question
jasbo
jasbo
