Question about Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporella 4500r
Hi i have a vaporella 4500r steam iron the iron works fine
but when i switch steam on it trips the power out on fuse box.
My domena steam press keeps tripping switch
It has a serious fault, the trip tripping is saving you from a electric shock.
By the way if your ELCB is a oblong brown or black box with a yellow or orange test button its way outdated I recommend you get it changed for a modern RCD (much safer)
Oct 17, 2014 | Vacuums
Polti valerpro 2400
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
May 05, 2012 | Polti Vaporetto 2400 Canister Steam Vacuum
Build up of deposits when steam iron is used, how do you get iron apart ?
You might be able to clean out your steam iron by putting vinegar in instead of water. It has worked on my steam iron as well as my coffee pot.
Jun 26, 2011 | Vacuums
Iron steams continuously even when staem switch set to off
Water still getting hot in there ,obviosly there is a problem with the switch or the liner in the iron just take the water out if you dont want it to steam
Feb 17, 2011 | Vacuums
I have a polti steam vaporella iron, it is struggling to get the steam through and when it comes it is in bursts and splatters out gunge.
It needs descaling just like a kettle we buy little tubes of descaler which you just put in where the water go's
Jan 17, 2011 | Vacuums
Steam builds up but does not come out of the iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jan 19, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
299 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
