Question about Dometic Rooftop RV Air Conditioner
Duo-them 15000 BTU roof air
Unit wont stop cooling I thought themostat was bad so changed Same problem. It will only cut off when I raise the themostat setting to the very top.
  • bigcbernard Aug 25, 2008
    Wall themostat that was change and have same results.
  • Dometic Master
  • 6,674 Answers
Is this a non-ducted system with dials to turn on it, or is it controlled by a wall thermostat ?
Posted on Aug 23, 2008
  • Mike Butler
    Mike Butler Aug 25, 2008
    Are you sure all the wires are where they are supposed to be on the thermostat ? I hate to ask this but have to, do you actually know by sound difference when your compressor kicks on & off ?When you say it won't stop cooling, do you know for sure the compressor is still working & fan is still blowing. The reason I ask is that some will continue to circulate the air, like it is still cooling, but the actual compressor has kicked off, and will kick back in when indoor temperature setting requires it to. Others will shutdown completely, compressor & fan, when it reaches desired temperature, and re-start when room reaches set temperature. Have you owned this RV long enough to know that the AC did actually work that way at one time? Perhaps if you can give me a model # on your AC unit, and thermostat, it would help me determine what's going on. Thanks
Fan runs. Why won't the compressor start?
probably a relay on module either bad or not communicating with thermostat.
Jul 12, 2015 | Coleman 15000 Btu Rv Roof Air Conditioner...
Suburban air conditioning
googled:
"suburban air conditioner 15000-48254C966" and got specs right here:
http://www.adventurerv.net/coleman-15000-btu-roof-air-conditioner-top-unit-p-1332.html
good luck.
Sep 03, 2014 | Electrical Supplies
15000 btu roof top does not cool but fan will run.
compressor capacitors, thermostat, relay module, bad compressor, lost charge of freon.
Apr 26, 2014 | Dometic 57915531 Air Conditioner
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Dometic 457915 roof air wont shut off automaticly
check fan wiring on board possible bad control board
Jun 13, 2012 | Dometic 457915 Duo Therm Brisk Air...
Have a Duo Therm 59516.531 15000 BTU blower motor does not run checked cap 5mf ok tried direct power still nothing any thought. thanks
if you tried direct power and still nothing then your fan needs to be replaced . there should be a a/c supply store near you . get the model - serial number on the fan or the unit itself to get the right fan for your unit . hope that helped
Jul 01, 2010 | Dometic 57915531 Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
184 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
