Question about Compaq NC8000 Notebook
AC Power and Battery Problem.....
Hi,I recently purchased a new battery for my Compaq nc8000 notebook and it worked for a couple of days,we had the laptop unplugged all night anfd the battery is dead,we plugged the ac power supply in this morning and for some reason it trys to turn on(nothing shows on the screen it doesnt get that far)and i see the power light and the 2 green lights come on for a second, then it shuts off.And it keeps doing that even when i unplugged the ac cord,i removed the battery and it did the same thing a couple of times then shut off.Its a brand new battery,and it worked since the day we got it(like a week ago)until now.
  • gameztile Aug 20, 2008
    yes it does the same thing for about5 seconds(trys to turn itself on and turns itself off)and now that ive had it plugged in awhile no charge light has been on this whole time until i go to start the comp,the lights cmon then the charge light flickers then shuts itself off then trys to restart itself then shuts down and it does this until i hold down the power button,then again no charge light appears.
  • 38 Answers
Sounds like the battery or possibly the charging circits themselves are the problem. Can you try turning on the laptop with just the power cord in and no battery?
Posted on Aug 20, 2008
  • Anonymous Aug 25, 2008
    Yeah, sorry to say, Its the laptop charging circuits.
    That's pretty fatal.
SOURCE:
Hi i was using m compaq nc8000, when it turned off suddenl even though it was plugged into the ac...now when i tr to turn it on it sounds like it is going to start,the yellow charge light comes on and then...
Hi
try removing you battery and powering it up....
it could be your charger,even if the power led is on there still could be a voltage failure...i,ve sorted a few laptops like that before.....
Or it could be the charging port connected to the motherboard??
Try to gently wiggle the adapter going into the charging port and powering it on...to see if that makes a diffence....
Hope this helps...if so please take the time to rate it,as i,ve taken the time to answer you...if i can be anymore help...
Regards
Apr 02, 2011 | HP Compaq nc8000 Notebook
Compaq nc8000 won't start please i wont to know the problem on the mother board after swicth on it will go off after 4 second and it wil not even show anything on the screen and the fan too will go off.
It could very likely be the motherboard causing the problem, in which case you're best off just getting a new computer rather than replacing or repairing the board, but it could also be a power issue.
Try turning the computer on with the battery installed and the AC adapter disconnected, and then try it with the AC adapter connected and the battery removed -- does it show the same symptoms both times?
Jun 08, 2010 | HP Compaq Business nc8000 Notebook
Hp compaq 6720 laptop, wont charge battery, bought new battery have same problem. have tried several different chargers and they are all working, but not charging battery
If the notebook does not charge even after replacing it with new battery and checking with several chargers then it is laptop power jack issue.
You may need to replace it. However to confirm the issue is with power jack just remove the battery and try to power on the notebook only with AC adapter. If it does not then it is the power jack which is allowing the ac power to be charged.
If your notebook is in warranty then you can ship it to HP and if it is out of warranty then check the link below, you can purchase the power jack of the laptop from here.
http://www.laptopjacks.com/parts/HP-6720s-laptop-parts-466.html
May 27, 2010 | HP Compaq 6720s Notebook
Compaq N610c does not power on on AC adapter or on Battery :(
it might be that the AC adapter is no more working. To confim this, remove the laptop battery and test the AC adapter with the laptop.
You can also borrow a friend's AC adapter and test it with your laptop.
I wish you good luck.
Mar 03, 2010 | Compaq Evo N610C Notebook
Hi forum, I have been using Compaq N610c notebook and was working fine but was not power ON . on AC adapter but it was working on Battery. From last day, the battery become zero showing battery indicator...
It's possible that the AC adapter "died", and then your computer ran on battery-power until the battery went to 0%.
Or, the socket on the laptop where the AC adapter connects could have broken, or become disconnected from the motherboard, such that the power from the AC adapter was not being accepted, meaning that your computer was running on battery-power.
Take the AC adapter and the computer to a qualified technician, who can test that the AC adapter is working fine, and can disassemble the laptop, to inspect that socket where it connects.
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Laptop shuts off, and wont turn back on.
when power off, push compressed air through vent.
If you can reach fan and remove dirt,
Insist on compressed air to clean every vent.
Install temp monitor to check if CPU is getting hot.
Dec 17, 2008 | HP Compaq nc8000 Notebook
My note book will not powering up.
Try to open the battery and connect your laptop to adaptor, then try to switch it on again. If nothing improves then there could be motherboard issue
Nov 25, 2008 | Compaq NC8000 Notebook
Battery Power
replace the battery
Jun 02, 2008 | Compaq NC8000 Notebook
Compaq NC8000 Notebook Logo
262 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
