Hi, Please find the work around steps to resolve duplex printing issue in Windows Vista. Please the send the *.gpd files to the cu via mail before doing the steps. Duplexer Printing for Windows Vista Troubleshooting steps 1.start-all programs- accessories ? cmd -right click-run as administrator 2.Stop the Spooler service - Type net stop spooler 3.Change current directory Type cd windows\system32\spool\drivers\w32x86\3 4.Backup the old gpd files - Type copy hp*.gpd *.bak 5.sent the zipped file to customers email address through astro and then download the file to customers desktop 6.extracted the files from the zipped folder and then pasted those files to windows\system32\spool\drivers\w32x86\3 7.Remove old BUD file Type - del HP*.bud file 8.Restart to spooler service - Type net start spooler 9.checked under printing preferences if the both sided printing is selected as automatic and then tried printing a two page document 10.checked whether its printing or not. 11.) Start-Control Panel- Printer & Faxes- Right Click On the printer -Properties-Device settings-Disable the manual Duplex printing-Click on Installed Two sided printing-click on apply & ok. 12) Then Go to Right Click on the Printer-Printing preferences-Paper quality-Select Two Sided Printing from the top drop down list where its showing What do you want to do? 13) From Print on both sides-Select Automatically from the drop down list. 14) Try to print on both side check whether its working or not.
Are you having a problem with this one computer AND only MS Office? For example, if you try to print something from Wordpad or another non-Microsoft office product, do you have the same problem? If so, I would delete that specific printer from your list of printers, reboot then try adding the printer again. It sounds like something is wrong with the way the printer is defined, not something with Office.
the printer is fine its the computer that you are printing from that is giving the wronge information. try reinstalling it onto that computer. and check that the background on the word documents are not black on print prevew first. or you have not chosen on the program you are printing from there is not a background colour that needs sending to the back.
That blank page is a separator page used when printing multiple documents. This function can be turned on and off in the printer settings. Go to Start>printers>right click on your printer and choose properties>click Printing Preferences at the bottom right hand side......snoop around in those tabs most likely an advanced or features tab you will find the setting for this.
Does it happen while printing from all the applications or from only any particular appication or from e-mail/web printing ?
Click Start (Windows Icon) - Printers Folder
Right click on the printer icon Officejet 5600 series and select properties. Click on the Advanced Tab. Enable the option Print Directly to printer. click Apply and OK. Check for the result.
This suggests the the 'copy' element of the software is not VISTA compatible.
In VISTA help in my computer - check out the 'compatibility' options
and select an operating system that the copy function did work under
when send something to my printer it will not print. Please help me.
Am using windows vista.
thanks
