How do I open the case of a Compaq evo d51S to upgrade memory?
Press the two side buttons, slide the case forwards, then lift it up and off. Sounds too easy, doesn't it?
The case can sometimes become stuck, requiring a bit more force. With the PC on a stable flat surface, press the side buttons and **** the top forwards vigorously. Be sure to press the rearward part of the side buttons so that the forward part starts to protrude a bit. This releases the catch behind the forward part of the button.
The case needs to slide forward about an inch to be able to lift off.
If your case is still not moving, you have probably encountered the dreaded stuck case syndrome. Looking at the case from the front, the left-hand side is stuck but the right-hand side releases. You are not alone, this has happened to more than one of us. I'm still not 100% clear on where the case jams, but there is a way to free it up.
NOTE: No tools are required to free the case cover, but you will most likely need pliers to straighten the clips afterwards!
Press both side buttons and slide the top cover forward as far as you can. Looking at the case from the front, twist the cover a little to allow the right-hand side to clear the clips. Once clear, lift up the right-hand side. It will catch on the chassis and, if fitted, the floppy-drive eject button. Gently ease the front of the cover forward so that the floppy-drive eject button clears the drive.
Next, slowly and firmly lift the right-hand side up and out past the chassis. This requires a bit of force (strength), but should not require violence (hitting).
If the case still won't release properly on the left-hand (CD/DVD) side, continue pivoting the case up from the right-hand side. At some point (cover probably around 60-75 degrees to its usual horizontal position), you will feel the metal clips resist. Release a little to see if the case is now free to move. If it is not, lift further, bending the clips as you go. Suddenly the case will be free to move forward! (You should not need to get to 90 degrees).
Once the cover slides forward, you will need to raise and lower it to work the clips out. The rear clips should release before the front ones and you can slowly pivot the cover out.
You will need to use pliers to straighten the clips before replacing the cover.
When replacing the cover, check to make sure that the cover slides easily back and forth before pushing it all the way back. The cover metal will only bend so many times before it breaks so you don't want to do this process more than once.
TD
Posted on Nov 27, 2008
  • tho7m Nov 27, 2008
    P.S. The one-sided cover sticking is due to the internal electronic solenoid "Hood Lock". If your system boots, use the BIOS to unlock the cover under Security -> Smart Cover. Only use the above if the system will not boot!
    TD
No idea.
Posted on Sep 01, 2008
Need internet drivers for compaq evo d51s
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
http://download.cnet.com/compaq-10-100-ethernet/3000-2112_4-62692.html
http://download.cnet.com/compaq-nc3120-fast-ethernet/3000-2112_4-71738.html
if these drivers are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name ethernet driver you might have to try a few times to get it right
hope this helps
Jul 19, 2012 | Compaq Evo D51s Pc/computer/desktop P4 1.8...
No audio video drivers
Ubuntu and OpenBSD come with adequate drivers. You could find Windows XP ones down at HP.com (since HP acquired Compaq,) or at Intel.com (since it's an Intel-based system) of course but that's a deprecated OS. Oh, and upgrade the memory.
Jul 31, 2011 | HP Compaq EVO D51S Intel Desktop PC -...
My compaq evo d51s is not displaying on the monitor at boot up.
Cleare Bios and replace the RAm if not solved use pci vga card, cirus logic or sis 6326 AGPcard
Nov 02, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Compaq evo d51s beeps on boot
Try to reseat the memory sticks. Sometimes they just need reseated.
Oct 25, 2009 | Compaq Evo D500 PC Desktop
Upgrading my compaq evo d51s
A ram upgrade could help, however you may need to think about upgrading your CPU also. First check if you can upgrade your CPU. Your best option may be to upgrade to a new computer altogether.
May 07, 2009 | Compaq Evo D500 PC Desktop
I cannot open my compaq evo d51s, any ideas?
if you look at the back of the workstation you will find a hidden screw next to the air vents, locate and unscrew, the casing should slide back away from the front and lift off to access the optial drive and ram
Apr 27, 2009 | Compaq Evo D500 PC Desktop
Compaq d51s with pent 4
Hi there
Yes that should be fine, the machine supports 2BG of memory 2x1GB each slot
Thanks for using Fixya!!!
Feb 01, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Computers & Internet Logo
627 people viewed this question
David Payne
David Payne
