Question about Hotpoint Aquarius WMA42 Front Load Washer
Fitting belt Trying to fit belt but it seems to small how is the best way of going about it.
    Genius:
  • 2,920 Answers
Have u put the belt on the tensioner? if so you have to pull on the belt to get the tensioner to move so you can out the belt on
Posted on Aug 20, 2008
1994 softail springer with harley carburator. fuel fitting on carb that was there had a plastic clip and small line going to hose. This hose broke and I was given a different fitting. This fitting presses...
The original fuel line fitting on the Keihen carb is a pressed in fitting made of brass and plastic. The plastic piece breaks off leaving the brass nipple in the carb. Harley makes a replacement fitting as well as the aftermarket parts suppliers. The Harley replacement is better because it's made completely of brass where the aftermarket replacements are made of brass and plastic like the original. To get the old fitting out, thread it with 1/4 X 20 tap and use a bolt, washer, and a deep well socket as a "puller" to get the old fitting out. To press the new fitting in, lubricate the fitting and the hole in the carb and use a vise to press the fitting in. Be sure to position the fitting correctly so that the fuel hose goes on in the right direction. I'm sorry but I don't have the part number handy. Your local dealer can look up the number easily.
Good Luck
Steve
Jun 07, 2011 | Harley Davidson FXSTS Springer Softail...
I am changing the vapor canister on my 04 toyota matrix xr and I'm having a problem with the small line that has a special clip on fitting. I can't get it off and I broke the line trying to get it...
You can get a new Fitting at the Toyota Dealer unless the Fitting is part of the line. Some Car Mauufactures, to make more of a profit, will only sell the part as a Whole Assembly i.e. Hose, Fitting, Canister, instead of selling them individually, so you are forced to spend more money. Hopefully that's not the case for you.
Aug 13, 2010 | 2004 Toyota Matrix
Changed timing belt on 1987 MR2 and now will not start.
seems like u did not align the cogs properly before fitting the belt.
if that is so then stopo trying to start the car until the belt is replaced after aligning the pulleys.
Mar 18, 2010 | 1987 Toyota MR2
Belt fitting on a Hotpoint WMA46
Hi.
These belts are difficult to fit.
They appear to be too small, but they are in fact a stretch belt, so their is no adjustment provided on the motor itself.
The best way to do it is remove the back panel as you have done, remove the top cover also.
The with someone's assistance, tilt the washer away from you at the rear, getting someone to hold it for you.
Put the belt round the motor pulley first, and start feeding it round the drum pulley, slowing turning the pulley as you do so, the further you get it round, the tighter it will become.
Just keep going, and the belt will go on, watch you don't trap your fingers in the process. If it slips off, then start again.
Good luck
Please rate my solution.
Thankyou.
Jan 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Electrolux front loader.EWF1090 i have the replacement belt but am having trouble fitting it. belt seems too tight. is same as the roken one. any suggestions?
put it on the small pulley first, then hold it on the large pulley with your hand and slowly turn the big drum, ensuring the belt stays on the big pulley as you move it. line up where you place the belt on the small motor pulley with the drum or it may slip off again.
Dec 23, 2009 | Electrolux Washing Machines
Where does the duck valve go in a Poulan 2150 chainsaw? Iam trying to replace the fuel lines . Does it go in the fuel tank? I need a diagram of the fuel lines.
is your fuel cap missing the hold down that keeps it from falling out of the tank.if the keeper is missing from fuel cap, the valve goes in the cap.if the cap is together then it just sticks in the fuel tank hole in the top...... hope this helps,let me know.................
Jun 03, 2009 | Poulan Pro Chain Saw 46cc 20"
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
F1245w
I have always fitted the the motor cog first then start by placing belt on half of the drum cog as much as you can, then by hand turn the drum and the belt should slip on.
lee
Jun 11, 2008 | Zanussi F1245W Front Load Washer
TROUBLE FITTING NEW BELT
i put the belt on large wheel then with a large Phillips screwdriver
though a socket slightly larger than the motor wheel put the belt around the socket on the screwdriver and put the driver in the small
hole in end of the motor wheel,lever the belt and slide the socket with the belt on down to the wheel ,push the belt over the socket onto the
motor wheel this my take 5-6 atemps but ive done it about 5 times
Feb 05, 2008 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
