Samsung SP43J6HD 43" Television Logo
Posted on Jun 15, 2011
I have a SAMSUNG HDTV Model number SP43W6HL, iv not used it for about 10 months. It has been kept unplugged in my bedroom so its not got damp or banged/bumped in any way. All it now dose when its plugged in, the stand-by light comes on and that is it. can you help me please or give me an idea what might be wrong with it, Thank you.
2 Related Answers
Anonymous
  • 304 Answers
  • Posted on Apr 14, 2010
SOURCE: Samsung HL-S5679W - Power-up issue
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Anonymous
  • 25 Answers
  • Posted on May 27, 2010
SOURCE: Why won't my Samsung HL-R4667W DLP tv turn on?
Theres a cover on the back that is vented w/4 screws on like the corners,also theres a symbol that looks like a "T" on it,take that cover off and right behind the symbol "T" an arm like plastic piece is what hits a lever inside when then cover is installed ,flip that little blue lever up and down a couple of times with the set unplugged reinstall cover making sure the "T" is in the position to hit the lever and tighten not too tight.
if this don't work it may be your colorwheel.Good Luck!
Hi guys I would like to know how old the SP43W6HL is? I have had mine for two years and would like to sell
Look in the back for manufacture date.But as i remenber these set are mostly produced in the years of 2001-2005 the high light of these tvs models.My best estamate as used and good conditon tv.Max price u could get for it about $800 max.
The unit only powers on sometimes or won't turn off unless unplugged. The color begins to fade and go out after being powered on for awhile
Go to online Encompass Parts Distribution and type in your model number they will have a listing for Boards and board numbers Color wheel BP96-00674A, Lamp BP96-00608A these amost common Parts Call Encompass Parts 1-800-638-3328 if you need anymore help let me know I have same TV. just repaired it 2 months ago.
2answers
Dehumidifier (challenge 12ltr) gives off a smell a nasty when running.
Clean the filters and the coil. Use a mild bleach solution if there is mold present.
Hdtv with purple lines
Since your set is a month old and in warranty, I suggest calling 1-800-Samsung and set up a repair appointment for a Samsung Field Engineer to come out and diagnosis the problem as the cause can be caused by a number of parts.
Samsung SlimFit TX-S3082WH Blurring on Left and Right Sides
your picture tubes is going bad. i've had 5 yes 5 of these tv's replaced by samsung/bestbuy. i've kept buying the PSP (product Service plan) now my most recent tv is doing the same. samsung no longer makes the picture tube for this model. i've already called them. it was a nice tv. i've gotten about 6 months out of each model. I'm moving on the LCD, nice rca 32 inch HDtv model at walmart for less than 500.00.
The part replaced is the blue convergence IC, part number usually
STK392-040 .A generic IC will last 10-12 months.You must have
OEM or better quality for durable repair. I use Panasonic brand.
Change both IC's for long repair duration.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
