Question about Compaq Presario Notebook
Hibernating am having problems shutting down the hibernating mode. pls assist
  • 38 Answers
What do you mean shutting down the hibernating mode? Stop it happening when the battery goes low, or shutting down into hibernate mode?
Posted on Aug 20, 2008
SOURCE:
My sony won't shut down. it will only hibernate
Go to power options and uncheck hibernate mode.
May 10, 2012 | Sony VAIO TR2A Notebook
Tip
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
on May 28, 2010 | Computers & Internet
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
I restored my Dell and when I did I lost the ablity to put it in sleep mode of have it power down without shutting it off. What do I need to do to get this feature back? P.S. I lost the restore factory...
For that you need to set some settings in control panel.
Go to start menu->control panel->power options .
Then in "Power schemes" set turn off monitor time as you like.
Also click on 3 rd tab "Hibernate" and enable it.
So when it hibernate it comes on previous state from where it shut down.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 31, 2009 | Dell Dimension E310 PC Desktop
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Compaq 714NR shuts down when hibernating
go to www.hp.com and update the bios looks like a problem with the hibernation ,mode
Jul 20, 2009 | Computers & Internet
Hibernation
This doesn't sound like a hibernation problem, it sounds to be much deep, motherboard deeper, but let's rule out the hibernation. Unplug the laptop, take out the battery, this will completely shut the machine down. Then put every thing back and restart. If it starts, then disable the hibernation mode in the display properties, screen saver tab, under the button that reads power. If it doesn't start, then the problem is with the motherboard or one of it's components. Take it in for a professional diagnostic, they will be able to tell you exactly where the problem is and if it's a replaceable component.
Jul 23, 2008 | Toshiba Satellite M105-S3004 Notebook
I want to reactive my HIBERNATE action
Plz Check
http://www.howtogeek.com/howto/windows-vista
/re-enable-hibernate-option-in-windows-vista/
Feb 15, 2008 | Computers & Internet
My laptop turns on itself, i don't know what's causing it. my windows(service pack 2) is fine and running smoothly....
Go to control panel. Power options and there u can see hibernate. enable hibernate and click apply. and come out and go for shut down and there u can see stand by shutdown and restart. then press shift button on keyboard the standby turn on to hibernate. then click hibernate it will shut down the entire system within 10 to 15 Sec try this. and Mail me on this mail ID
[email protected].co.in
Dec 19, 2007 | Compaq Presario X1000 Notebook
Compaq Presario Notebook Logo
159 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
